rear disc brake swap question
my question is, will a '94 integra LS rear disc brake swap on my '99 civic w/ factory 14in HX wheels fit? will there be any room for clearance or will i have to upgrade to a 15in wheels? i prefer not b/c im liking my HX wheels and if im correct LS integras came w/ 14in steelies. iunno lmk wsup all u brake swappin' pro's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2vu »</TD></TR><TR><TD CLASS="quote">rear brakes fit fine...front wheels will not fit over the brakes will not if u get gsr...i got hx's on my car with gsr rear brake so im SURE!! Good luck with the brake swap</TD></TR></TABLE>
oh no, im just swapping out the rears from drums to disc brakes. btw is there anything bad im going to be running into, like major or any modifications?? b/c everything i will be needing for this project is coming straight out of a LS teg and my drums will be goin on his teg, so we're literally will be "swapping" our brake set ups. thanks
As long as you use your front brakes, you will be fine. I just put some 13" steelies on my friends totaled 97 LS.(in the rear only)
Edit: The only real problem you will run into is the e-brake cables. The e-brake cables are a little short (no big deal). I put the same swap on my 96 coupe and they work great. But if you want the "correct" cables get some of a 99-00 Si. If you ever plan on getting Braided SS lines for the rear discs, get them for a 99-00 Si as well.
Edit 2: Last edit I swear. MAKE SURE YOU USE A FLARE NUT WRENCH FOR THE BRAKE LINES!!!!!!!!!!!!!!!!!!!!!!!
you should be fine bro...if u know enough about what ur doing...its like direct swap over...make sure u get the integra ebrake cables though..uhh nothin major in mods or anything...i had a little issue of getting the brake line out that was about it...stupid clip was in the way i couldnt see cuz of all the dirt that built up
k thanks bro, btw i have a 99 sedan, i don't think it'll be any difference in vehicle length. my sis has a 99 coupe and when we park in the garage from front to rear bumper we're exactly the same length.
89dxhunchback
37
Jan 1, 2005 12:07 PM
