will a 94-97 turbo kit fit a 90-93?
it will be close...you could probably make all the plumbing work with some creativity with couplers and the like, or have a welder go at it...but, as previously stated, the turbo manifold will not bolt up to your motor...everything else should be ok though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly »</TD></TR><TR><TD CLASS="quote">probably everthing but the manifold.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jed Atreides »</TD></TR><TR><TD CLASS="quote">Nor the intercooler pipes.</TD></TR></TABLE>
not exactly, but im sure they can be modified to fit the 4g with a little fab work...
No.
Not only for plumbing reasons but also because the ports on the exhaust manifold won't line up.
f22b1/2 : 0 00 0
f22a1/4/6: 0 0 0 0
Although you can do a head swap and use a f22b1/2 manifold and custom make everything else or you can search under dsm turbo or junkyard turbo. Another source to look at is http://www.cb7tuner.com/vbb
f22b1/2 : 0 00 0
f22a1/4/6: 0 0 0 0
steve96accord
Nov 18, 2005 07:25 PM
crxzcracer
Mar 14, 2005 08:07 PM
