Need an answer to some ?'s... QUICK!
Ok guys heres the deal... i have a 94 accord lx 2dr h22 swap... im in the process of putting together the power steering... i have a 97 prelude bracket on the way, and i have all the neccessary components to make it work cept for the ps line... now heres where my question is.. my buddy has a powersteering line from a 92-96 lude.. will it fit my accord.. and line up correctly..? ( i have a 94 accord p/s pump).. any help would be great...
next question has to do with carbon fiber hoods... has anyone had problems with fittment with abs c/f hoods...? if so, what were they. anyone recomend somewhere to get a hood im not going to have any problems with..?
any help is appreciated, thanks.
ok, if the motor is from a 92-96 then im almost sure the power steering lines will match up, the other thing is that the carbon fiber hood will match up fine, depends on which brand you use. I have a VIS, and its perfect.
no, the line won't fit...since the power steering rack is where the line is from, it has nothing to do with the motor...also, the accord pump and the prelude line won't work together...you seem to have made a mess of the two different options for making power steering work with an h22....
the original options were:
-use the 97+ prelude bracket with accord p/s pump and line and all accord p/s parts....
or
-use the prelude pump and bracket from the h22 and braze a prelude p/s line to the oem accord line...
how much was cut off the original accord line? is there still enough to have the prelude line attached? if so, then it seems option number 2 will be your best bet...
or
jmoe7135
Feb 9, 2014 12:44 AM
KStuned
Sep 11, 2003 11:48 AM
