JUST CHANGED MY FUEL FILTER AND ITS STILL BOGGIN.. ANYONE HAVE AN IDEAN WHATS WRONG???
Old May 10, 2005 | 01:19 PM
superhatchbackbros's Avatar
Default JUST CHANGED MY FUEL FILTER AND ITS STILL BOGGIN.. ANYONE HAVE AN IDEAN WHATS WRONG???
ON MY 89 honda civic hatchback.. 1.5l i changed my oil flushed out rad and i filled all fluids.. now i changed my plugs and i have nology hot wires on my car.. and i took for test drive and with the new filter i thought was the problem.. its still doing it?? now i over looked this but i put a new alternator belt on and the belt is really lose.. would that make the motor bog? please let me know im diein over here.. runin out of ideas why it would be boggin.. thanks everyone in advanced..
Old May 10, 2005 | 01:37 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: JUST CHANGED MY FUEL FILTER AND ITS STILL BOGGIN.. ANYONE HAVE AN IDEAN WHATS WRONG??? (superhat
you should make at least 4 more threads about this..... take those nology wires and toss them, your better off running oem, have you checked you cap and rotor, especially the rotor screw, is the car "bogging" all the time, or at a certain rpm? Have you checked you cat to see if its plugged? What do your old plugs look like? your tps or map sensor could be bar also, there are so many variables
Old May 10, 2005 | 01:46 PM
naptownrex's Avatar
Double check all your plugs, like he said the tps, etc. make sure they're all on there tight. Rotor is a good thought as well, but if all that looks good, check you coil, and replace with a known good one. I had a bogging prob a few months ago, and i replaced my coil, and it worked great. It could only be one of two things- your motor isnt getting the correct amount of fuel, or your ignition system is not burning it comepletely. Ive got my money on tps or something in the dizzy though. good luck
Old May 10, 2005 | 03:00 PM
kaoss_11's Avatar
B A N N E D
dizzy i think
Old May 10, 2005 | 03:25 PM
riceisnicenv's Avatar
Default Re: (kaoss_11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 &raquo;</TD></TR><TR><TD CLASS="quote">dizzy i think </TD></TR></TABLE>
dizzy/timing related issues
Old May 10, 2005 | 03:50 PM
SwissChEz82's Avatar
Default Re: (riceisnicenv)
You said it's bogging, my car has been bogging since I installed my DOHC ZC but it's finally stopped bogging after replacing the distributor.
Old May 10, 2005 | 03:54 PM
TAG's Avatar
TAG
Default Re: (SwissChEz82)
Toss the Nology wires, seriously. I had 2 co-workers (both Engineers) with relatively-stock Hondas/Toyotas. Last summer both started experiencing bogging.
One of them replaced wires with stock (NGK) wires and the problem was solved
The other followed suit and his problem went away immediately as well.
Sometimes stock rules
.............4 more threads, too funny
Modified by TAG at 5:59 PM 5/10/2005
Old May 10, 2005 | 04:23 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (TAG)
injectors?
Old May 10, 2005 | 04:46 PM
FalkenSiR's Avatar
Default Re: (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TAG &raquo;</TD></TR><TR><TD CLASS="quote">One of them replaced wires with stock (BGK) wires </TD></TR></TABLE>
Now your last bet would be to try a diff set of injectors.
Old May 10, 2005 | 04:59 PM
TAG's Avatar
TAG
Default Re: (fast88std)
[QUOTE=fast88std]
Haha...good catch. -- FIXED
Old May 10, 2005 | 07:30 PM
I PUT AN O2 SENSOR IN AND I TOOK OFF MY NOLOGY HOT WIRES AND PUT ON OEM STOCK WIRES AND THE BOGGIN WENT AWAY.. SO EITHER THE WIRES OR O2 WAS THE PROBLEM THANKS GUYS.. OH THE REASON I TOOK MY WIRES OFF IS BC I TOUCHED THE WIRES WHILE THE CAR WAS RUNIN AND THE WIRES SHOCKED ME NEAR THE DISTRIBUTOR.. SO I THINK THAT WAS THE PROBLEM WHY IT WAS BOGGIN.. THANKS AGAIN GUYS..
Old May 10, 2005 | 08:24 PM
TAG's Avatar
TAG
Default Re: (superhatchbackbros)
Awesome - glad to hear you fixed it!
Thanks for the update
admess188
Aug 13, 2011 07:29 PM
99blackdc2
Oct 28, 2006 08:40 PM
STUCKED
Jun 16, 2006 08:04 AM
EF4lyfe
Sep 27, 2004 03:59 PM
Hybrid Boy
Sep 1, 2002 03:16 PM
