cel #61 changed o2 and still CEL#61
Old May 10, 2005 | 12:44 PM
93FastLs's Avatar
Default cel #61 changed o2 and still CEL#61
i just changed the o2 sensor in my car, cause it was coming up with a cel 61 primary o2 sensor.so after i changed it it still came back up do i have to let the car run for alil while after install...or it doesnt matter..
Old May 10, 2005 | 02:33 PM
drdisco69's Avatar
Default Re: cel #61 changed o2 and still CEL#61 (93FastLs)
Did you clear the code after you changed it?
Old May 10, 2005 | 04:44 PM
93FastLs's Avatar
how do you clear the code
Old May 10, 2005 | 05:30 PM
drdisco69's Avatar
Default Re: (93FastLs)
..What kind of car is it? Searching will find you everything you need, by the way...
Old May 11, 2005 | 06:01 PM
93FastLs's Avatar
92 vx 95 gsr swap
Old May 12, 2005 | 04:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote">92 vx 95 gsr swap </TD></TR></TABLE>'95 GSR doesn't have a code 61. What ECU are you using? How are you reading the code?
Old May 13, 2005 | 03:39 PM
93FastLs's Avatar
p72...code 61 is primary o2 sensor
Old May 16, 2005 | 04:22 AM
JimBlake's Avatar
P0133 = flashing-CEL code 61 = primary O2 sensor slow response. I thought that code didn't exist until OBD-2 ('96). That's why I asked what ECU.
Slow response is the kind of code that isn't likely caused by bad wiring. There's different codes for low or high voltage, those can be caused by an open or short. So it's still kinda confusing to me, since I figured the response of the sensor didn't change from OBD-1 to OBD-2, only the newer P72 ECUs had more stuff programmed on it.
Old May 20, 2005 | 05:18 AM
SpoonEk253's Avatar
Default Re: (JimBlake)
do you guys know if the 96+ obd2 gsr have 2 o2 sensor or just 1?
Old May 20, 2005 | 05:39 AM
JimBlake's Avatar
Default Re: (SpoonEk253)
ALL OBD-2 cars (beginning in 1996) must have another O2 sensor after the cat.
DarkBB4
Aug 27, 2005 09:31 AM
MysteryWagon
Mar 10, 2005 08:07 PM
awdvr6
Mar 12, 2004 10:36 AM
00WhiteEKy
Aug 24, 2002 04:13 PM
S13 slide
Jun 2, 2002 03:30 PM
