Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust?
Old May 10, 2005 | 07:19 AM
B16Civic93's Avatar
Default Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust?
on low boost setting the boost goes back and forth in between 5.5 and 6.5, all the way up once it hits full boost. what can i adjust to make this not happen? btw its a greddy 18g in case that matters.
would increasing the warning more than it already is make a difference or should i mess with the gain or start boost? let me know
Old May 10, 2005 | 07:22 AM
done's Avatar
Default Re: Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust? (B16Civic93)
sharpen the gain a bit..
Old May 10, 2005 | 04:10 PM
B16Civic93's Avatar
Default Re: Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust? (Jordo@KAP)
sharpen would mean raise correct?
also should i raise the warning level very high and just pay attention to the boost gauge the first couple pulls and then turn it down until it starts to make a difference? could that be doing it?
Old May 10, 2005 | 04:21 PM
CRVRX's Avatar
Make sure the boost cut isn't set too low. Also make sure the "Gain" isn't higher than your set boost.
Old May 11, 2005 | 07:42 AM
B16Civic93's Avatar
Default Re: Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust? (CRVRX)
what happens if the gain is higher than the set boost?
Old May 11, 2005 | 01:34 PM
Cee_mon's Avatar
Isnt it the shaper it is the least boost spike and holds the best once at full boost level?
Old May 12, 2005 | 07:09 AM
B16Civic93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">what happens if the gain is higher than the set boost?</TD></TR></TABLE>
Old May 12, 2005 | 01:12 PM
M.A.R.C.'s Avatar
make sure the boost limiter (2nd red screen) isn't too low. and make sure the gain as people said isn't higher than the set boost (first screen when u hit mode).
IN VTEC
Feb 13, 2008 07:07 AM
RyanEJ8
Mar 23, 2007 09:29 AM
br1ev8
Apr 6, 2006 02:44 PM
skilzz
Oct 24, 2002 03:37 AM
