boost on an ls
Old May 9, 2005 | 09:25 PM
5gSiB20's Avatar
Default boost on an ls
ok me and my friend were arguing bout an ls with a 150shot and 8lbs of boost would it hold it or not on stock internals??? i said it wouldnt will some one please prove one of us wrong!!!!
Old May 9, 2005 | 09:28 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: boost on an ls (5gSiB20)
yeah it'll hold.
but for how long? that's the question.
Old May 9, 2005 | 09:29 PM
5gSiB20's Avatar
Default Re: boost on an ls (Screwtape:)
ahhh smart... daily driven
Old May 9, 2005 | 09:36 PM
Multi-paradigm
hm...probably not too long. the 8psi of boost shouldn't be a problem. but how often is 150-shot used? daily for getting up freeway ramps? or?
Old May 9, 2005 | 09:37 PM
JohnnyWash1's Avatar
8psi + 150 shot = blown motor at some point. That is asking alot.
Old May 9, 2005 | 09:52 PM
need4speed93's Avatar
Default Re: boost on an ls (JohnnyWash1)
my friend had a turbo put on his ls/vtec swap and put only a 50 shot on it, the mechanic that did it told him he'd be lucky to have it last over 10,000 miles. well he went through about 2 bottles and threw a rod. later when he took it apart he found out the crank and everything was messed up.
make sure you have good tuning and with big shots of juice id say get the block sleeved.
Old May 9, 2005 | 10:22 PM
Default Re: boost on an ls (need4speed93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by need4speed93 &raquo;</TD></TR><TR><TD CLASS="quote">my friend had a turbo put on his ls/vtec swap and put only a 50 shot on it, the mechanic that did it told him he'd be lucky to have it last over 10,000 miles. well he went through about 2 bottles and threw a rod. later when he took it apart he found out the crank and everything was messed up.
make sure you have good tuning and with big shots of juice id say get the block sleeved.</TD></TR></TABLE>
Old May 9, 2005 | 11:57 PM
hatch34's Avatar
why would you ever think to do a 150shot on a stock motor thts a little crazy in my opinion just do the boost it will be fast enough
Old May 10, 2005 | 12:16 AM
92jdmhatch's Avatar
Default Re: boost on an ls (hatch34)
boost 150 and squeeze 8 shot
Old May 10, 2005 | 12:31 AM
Captain_Kicker's Avatar
Default Re: boost on an ls (92jdmhatch)
Count that motor out in 100 miles
Old May 10, 2005 | 02:06 AM
lone's Avatar
Default Re: boost on an ls (Captain_Kicker)
why not just up the boost and forget about the 150 shot
Old May 10, 2005 | 02:15 AM
GDM Z28's Avatar
Default Re: boost on an ls (lone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lone &raquo;</TD></TR><TR><TD CLASS="quote">why not just up the boost and forget about the 150 shot</TD></TR></TABLE>
smart man ^
&lt;~~ had 2 stock ls turbos
one made 304 at 14 psi (oil pump gear blew up n i spun a bearing)
the other made 282whp at 11 psi (boost spike killed it....fastest stock ls ive ever been in when it hit 28psi for 2 gears )
b00stedda
Nov 10, 2007 09:34 PM
crxsteve
Nov 18, 2006 06:41 AM
turboed_ef
Mar 12, 2005 05:18 AM
fabe85
Dec 19, 2004 10:53 PM
ThisLittleSleepeR
25
Aug 13, 2003 10:39 AM
