help help help with my b16a
Old May 9, 2005 | 07:10 PM
matthevelli's Avatar
Default help help help with my b16a
Hey guys...well today was the finishing touches on my b16a swap in my 95eg. I had to do the wiring and fluids..it started fine and when i went to take it down the road it wouldnt accelerate like past 10mph..it kepts falling on its face..(bogs) i checked everything over and eveything seems to be correct..There are some things i need to take care of, for example..Knock sensor was broken, i ha ve one coming so i still need to replace and wire to the ecu..running just a header cuae my hi flo cat didnt bolt up. and my tps sesore is a little cracked but still snaps together...Now when i wired the 02 sensor i had to come from one wire to 4 wires. what i search here on H_T i read i had to send one wire to the ecu (A6) connect one wire to the harness that i already had a plug for.. send one wire to the junction plug and one to the thermosdat ground.. now im positive i have then all in the correct place but im not positive on junctin plugs..do you just splice the power wire into one of the yellow wires and the ground can you just ground it to the thermosdat bolt? if you have any idea what could be wrong with my car please let me know..
-dave
Old May 9, 2005 | 07:39 PM
JDM EJ1 95's Avatar
does it throw any codes? if so... go jump them and figure out what codes it is throwing and tell us..... we can help a lot better if we know these things
Old May 9, 2005 | 07:52 PM
Default Re: help help help with my b16a (matthevelli)
yeah i tried to get the codes by jumping..but instead of my CEL blinking my airbag light was blinking but it wouldnt stop blinking until i pulled out the jumper
Old May 10, 2005 | 06:51 PM
anyone else have an idea what is wrong with my car?!!!!
halfkoreanboy
Nov 2, 2010 11:15 AM
97hatchb16
Sep 4, 2006 08:42 PM
AdamITR
May 14, 2003 05:44 PM
