pics of your turbo setup with ac
i would like to see some pics of your turbo setup with ac compressor and ac condensor. on my setup i can fit the ac compressor but seems no way to fit my ac condensor with fan anywhere.
yeah bump it up. i know there are too many guys with ac on with their turbo setups but i cant seem to find any on the searches.
running a bmc manifold on mines
http://www.we-todd-did-racing....D.jpg
i dont have the a/c comp on there cause it messed up but as you can see the mani/wastegate comes really close to the radiator. i just removed the integra radiator and with a civic one! hope its what you looking for. if you cant tell its a dc2
pics aren't that great but full race mani, AC, 3" DP, traction bars, daily driven.
AC lines are just too damn close to mani, I plan to have a set custom made from an AC shop and route them inside bumper in front of radiator support.
edit: put the fan on the opposite side of the ac condensor and get a half size radiator if you do not already have one.
I had to relocate the fan. I used a slim Pep Boys pusher fan. Here's a pic from the inside:
And here's a pic from the front:
You can barely see the pusher fan, it's just a round outline on the heat exchanger.
i have ac intact except for the fan.
the only problem i have is the metal bar in the middle going across my a/c condensor and radiator and can't have my pusher fan right against the condensor...
will it still work?
will it still work?
That's an A/C line. I cut it, bent the ends out, and extended it towards the front of the car with a couple of pieces of high pressure rubbber A/C line I got from NAPA. Have your systen evacuated before you do this or it will make a huge mess.
