Friends' horn cuts in and out.
Old May 9, 2005 | 06:01 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Friends' horn cuts in and out.
A friend of mine has the 2005 GSX-R 1K () and his horn just periodically decides to quit working.
Any idea where we should look? Every time he takes it to the dealer, it works again.
Old May 9, 2005 | 07:10 PM
Newkdog's Avatar
I miss Andrea.
Damn that is interesting, I guess check all the wires leading from the horn...
Old May 9, 2005 | 07:11 PM
falcongsr's Avatar
What is this crap?
Default Re: Friends' horn cuts in and out. (Ross R)
Have him change the horn fluid. It gets dirty and causes the horn to lock up. Very common.
rioninja's Avatar
I have seen horns that will "stick" when you try hitting them at idle. Usually a situation where the horn is partly stuck, and the bikes electrical system isnt providing quite enough voltage to buzz it. next time it stops working, tell him to try revving the bike up a few grand and trying it again.
Other than that, could be as simple as the button itself not making a good connection.
Old May 9, 2005 | 09:00 PM
marmaladedad's Avatar
What is he doing when the horn doesn't work? What is the dealership doing differently?
Old May 9, 2005 | 09:14 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: (marmaladeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">What is he doing when the horn doesn't work? What is the dealership doing differently?</TD></TR></TABLE>
Hitting the button, lol.
When we're out on the road, it works intermittently. We'll be at a stoplight, beeping and revving like ********, and his horn will just cut out. Next time we're stopped, it will work. Really strange.
Old May 9, 2005 | 11:21 PM
.Ash's Avatar
i think its suzuki's new idiot-proof feature.
Old May 10, 2005 | 05:41 AM
falcongsr's Avatar
What is this crap?
Default Re: (Ross R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">Hitting the button, lol.
When we're out on the road, it works intermittently. We'll be at a stoplight, beeping and revving like ********, and his horn will just cut out. Next time we're stopped, it will work. Really strange.</TD></TR></TABLE>
ohhhhh....that just means its overheating. let it cool off. and change the horn fluid like i said.
Old May 10, 2005 | 05:49 AM
Ross's Avatar
25 Year Member
Community Builder
Default Re: (falcongsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falcongsr &raquo;</TD></TR><TR><TD CLASS="quote">ohhhhh....that just means its overheating. let it cool off. and change the horn fluid like i said.</TD></TR></TABLE>
Well, overheating isn't an easy answer. The horn cuts out when the bike is cold too.
We thought it was just a problem with the wires and circuits inside the horn being cold, and figured once the bike warmed up, the problem would go away. But it's always there, albeit at random times.
I'll look into changing the horn fluid.
Old May 10, 2005 | 06:04 AM
Apocalypse's Avatar
I'll look into changing the horn fluid. </TD></TR></TABLE>
ROFL! n00b!
Does it happen when the bike if not running? It sounds like there is a loose wire and the vibration of the bike is jostling it. I know you said you checked all the wiring but electrical systems are so finicky there might be something you can't really see with the naked eye.
Old May 10, 2005 | 06:10 AM
falcongsr's Avatar
What is this crap?
sorry, please ignore everything i've said in this thread.
Old May 10, 2005 | 06:40 AM
ProjectF4's Avatar
never ^
i had the same problem, and had to not only change the horn oil, but i needed a new filter... very pricy
Old May 10, 2005 | 01:16 PM
Home Skillet's Avatar
Default Re: Friends' horn cuts in and out. (falcongsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falcongsr &raquo;</TD></TR><TR><TD CLASS="quote">Have him change the horn fluid.
I was seriously drinking a cup of tea and it snarfed back up into my nose, arsehole!!!
Old May 10, 2005 | 01:44 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Friends' horn cuts in and out. (Home Skillet)
lol...does the horn fluid/oil just not exist? Doesn't seem like a horn would need to be lubricated, but ya never know.
&lt;-- NOT a gearhead, although I did install my windscreen on the SV
Old May 10, 2005 | 01:46 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">lol...does the horn fluid/oil just not exist? Doesn't seem like a horn would need to be lubricated, but ya never know.
&lt;-- NOT a gearhead, although I did install my windscreen on the SV</TD></TR></TABLE>
I see bad things in your R6's future
Old May 10, 2005 | 01:59 PM
Ross's Avatar
25 Year Member
Community Builder
Default Re: Friends' horn cuts in and out. (RebornGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RebornGSR &raquo;</TD></TR><TR><TD CLASS="quote">I see bad things in your R6's future </TD></TR></TABLE>
All you're going to see is the collection of beautiful women I put on the back.
Nice horn oil joke, falcon...lol. Me = 0wnd...I replied without actually considering the ridiculousness of what you had said.
In all seriousness, there's no rhyme or reason to his horn working or not working. Temp, engine revs etc don't hold any hints. He's no more technically inclined than I am, however...so I don't know how this is going to get fixed.
Old May 10, 2005 | 03:18 PM
falcongsr's Avatar
What is this crap?
its definintely an electrical connection that is intermittent. the only constant in the problem is the engine vibration is probably causing it. it might be a loose connection or maybe in the horn itself.
usually things like this are fixed by just disconnecting and reconnecting everything assoicated with the horn from the button to the horn itself until you find what is causing it.
now, about that blinker fluid...
Old May 10, 2005 | 03:39 PM
EGlovr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross R &raquo;</TD></TR><TR><TD CLASS="quote">...does the horn fluid/oil just not exist? </TD></TR></TABLE>
lol
Old May 10, 2005 | 06:16 PM
Ross's Avatar
25 Year Member
Community Builder
now, about that blinker fluid...</TD></TR></TABLE>
LOL, eat a D***. And when you're done, you can pass it over to Project F4
PatrickGSR94
Jul 14, 2007 03:32 PM
Mistermark
11
Mar 20, 2006 10:51 AM
.cingham
Honda Motorcycles
10
Oct 20, 2005 11:16 AM
5po0n_Dc2
Honda Motorcycles
Oct 14, 2005 11:12 AM
saanemon
14
May 29, 2003 01:50 PM
