bad idle?
Old May 9, 2005 | 05:57 PM
SI-vtec92's Avatar
Default bad idle?
i just swap a b-16 into my hatch. when i start it up it runs perfect when its cold. after it warms up the idle drops from 1k toabout 200 rpms i've done everything i could think of. if anyone has a clue or even had the same problem please give some suggestions.
Old May 9, 2005 | 06:06 PM
Deathwish's Avatar
I was under the impression thats a good idle?
Old May 9, 2005 | 09:04 PM
Fongman's Avatar
Default Re: bad idle? (SI-vtec92)
Thats too low? Have you try cleaning you idle air valve? and what is the idel when cold?
Old May 9, 2005 | 09:29 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (Deathwish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deathwish &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression thats a good idle?</TD></TR></TABLE>
200 RPM is kind of low.
hm...did you try adjusting your idle screw?
Old May 10, 2005 | 03:25 AM
SI-vtec92's Avatar
Default Re: (Screwtape:)
i was tired last night. i ment to say that when its cold it idles at like 1200 to 1500 rpms. when it \s warm it drops from a 1000rpms to 20orpms then back up to a 1000. some time it stalls. i put a type r intake cam, manifold and throttle body on it,. i'm throw just the o2 sensor code and i just recently threw the knox sensor code
LukieLuc
Sep 19, 2007 07:37 PM
BrokenRex
Oct 13, 2005 08:25 PM
integra-modder
May 30, 2004 02:18 PM
jdmstreethatch
13
Apr 5, 2004 11:09 AM
