Which clutch disc is this? (ACT or Honda oem)
Old May 9, 2005 | 03:32 PM
TAG's Avatar
TAG
Default Which clutch disc is this? (ACT or Honda oem)
I'm trying to get a definitive answer....so I can be sure to order the same disc.
I looked all over and didn't see anything saying "ACT" on it. But I bought it in '99 with an ACT HD pressure plate. Just don't recall if this is oem or act. Thx
Old May 9, 2005 | 03:53 PM
ACRProject's Avatar
Default Re: Which clutch disc is this? (TAG)
that disk looks stock because ACT discs come with 6 springs not 4
Old May 9, 2005 | 03:54 PM
Ronin150's Avatar
On mine there was an orange sticker on one side. It would be in the middle so it can't get rubbed off. Also if it wasn't used it would have ACT stamped on the outer ring (not sure what it's called.) Don't mind the middle finger I was just mad because I bought the wrong clutch, but you can see where the stamp would've been.
Old May 9, 2005 | 04:05 PM
TAG's Avatar
TAG
Default Re: Which clutch disc is this? (Ronin150)
Ronin150:
Thanks for the good info. Much appreciated
Haha..I think I have SEVERAL pictures of me flipping stuff off so don't even worry about it
ACRProject:
Are you sure about that statement?
(that disk looks stock because ACT discs come with 6 springs not 4)
Check out this picture from ACT's website (I ran through their eStore for the 90 Honda CRX Si). It has 4 springs
Modified by TAG at 8:39 PM 5/9/2005
Old May 9, 2005 | 09:37 PM
ACRProject's Avatar
Here is my 90-91 integra act clutch disc, it has 6 springs. It could just be the b-series, but all b-series act clutch discs i have owned all had 6 springs. Can't always go by the pictures of the website, since they might not be for your application.
Old May 9, 2005 | 09:44 PM
wrXtian's Avatar
Default Re: Which clutch disc is this? (ACRProject)
i think exedy is 4 springs also
Old May 9, 2005 | 09:50 PM
TAG's Avatar
TAG
Default Re: Which clutch disc is this? (D16A6_HF)
ACRProject:
Good info/reply.
My fault - I neglected to mention this is for a D series engine (90 CRX Si tranny with DOHC ZC blacktop)
I'm not sure if the D series clutch discs from ACT are mostly or all 4-spring?
Anyways, despite all the helpful posts, I'm still having difficulty making sure which one it is. So I'm going to try asking the mechanic at my shop tomorrow morning. Maybe he will see something on the surface that we're missing due to the med-res photo I took.
Old May 9, 2005 | 11:09 PM
CRseXy's Avatar
Stock honda Clutches have rubber bushing things insted of springs. At least my old one did.
Old May 9, 2005 | 11:37 PM
Rywire's Avatar
Default Re: Which clutch disc is this? (pogiTSI)
look at the serial num, and match to the act website
Old May 10, 2005 | 12:12 AM
Jester88Si's Avatar
my act clutch for my d16a6 has 4 springs
Old May 10, 2005 | 10:12 AM
TAG's Avatar
TAG
Default Re: (Jester88Si)
Update!
This morning before work, I took my clutch components to my local tuner shop
Their mechanic had actually remembered driving my CRX from last year and said the PP was the Xtreme model and not the Heavy Duty. He said my pedal effort was *way* to stiff to just be from the clutch pedal.
Ah, that explains it!
All along I was thinking...how could my pedal be SO stiff, when I only had the Heavy Duty and not the Xtreme model.
I'm kind of annoyed, that after all these years of killing my left leg in traffic, that my friend who helped me suggest parts for my setup recommended the stiffer pp, groan
I wished I had gone with the Heavy Duty one.
The mechanic looked at the friction disc and said it was almost certainly the ACT street disc. Especially since there was so much material left on the disc (maybe 20% used over 5 years of occasional driving) He said if it was a Honda/OEM disc, it wouldn't have lasted this long (he said stock discs get chewed up pretty badly/quickly when mated with aftermarke/stronger pressure plates)
So, Cliffs Notes:
- My pp was : ACT Xtreme
- My fd was: ACT organic street disc
So now I will be going with either the ACT HDSS or Clutchmasters Stage 1.
Depends on what kind of prices I can get.
Thanks for all the replies with info.
Modified by TAG at 11:23 AM 5/10/2005
Old May 10, 2005 | 10:30 AM
PaImportTuner's Avatar
Default Re: (TAG)
i'd stick with the xtreme. and get a 6 puck ceramic or kevlar disk. lol
Old May 10, 2005 | 10:34 AM
TAG's Avatar
TAG
Default Re: (PaImportTuner)
Haha...you had me there for a second! sigh!
Old May 10, 2005 | 10:38 AM
Default Re: (TAG)
i'm serious, i drive like this DAILY in my b16 crx. when i drive my stock da teg my foot falls to the ground with ease.
Old May 10, 2005 | 11:01 AM
TAG's Avatar
TAG
I think your calf muscles must look like the Hulk's!
My goal is to have my clutch pedal be no stiffer than the E36 M3 clutch...that one is *just* about right for me.
Old May 16, 2005 | 03:28 PM
smoke07018's Avatar
it a stock disc
Old May 16, 2005 | 03:29 PM
TAG's Avatar
TAG
Default Re: Which clutch disc is this? (smoke07018)
Bzzt - wrong
It's an ACT. Read the posts above
B_Swapped93
Nov 17, 2013 08:42 PM
NVturbo
Mar 13, 2005 08:30 PM
LudeyKrus
Oct 11, 2003 08:38 AM
genetsang
Jan 26, 2003 07:35 AM
Mojo-Jojo
Sep 23, 2002 01:28 PM
