My 929RR shutoff on Freeway!!Yikes!
Old May 9, 2005 | 02:11 PM
Gearspeed-Performance's Avatar
Default My 929RR shutoff on Freeway!!Yikes!
I was cruising about 80mph on the freeway...not far from my destination and my bike shut off. I tried to start it back up and it would stay on for a bit but shut off after a few seconds. I then proceeded to remove the seat and found that some of the fuses were a bit wacky but, not completely out of place. I pushed them all back in and started the bike and viola! The bike ran perfect although it does have a little idle jump from time to time. Just wondering if anybody has experienced this problem...Kind of puzzling
Old May 9, 2005 | 02:32 PM
Newkdog's Avatar
I miss Andrea.
Wow man, glad you came out unscathed.
Old May 9, 2005 | 03:02 PM
Default Re: (Newkleus)
I had to dip over to the shoulder pretty quick and still keep the shiny side up with all the gravel from the side of the road!
Old May 9, 2005 | 04:46 PM
integrator43's Avatar
Default Re: (GearSpeedEF9)
weird, occaisionally my 929 would not start last year. would only happen after a good long ride 60 miles+. i never had the problem of it not shutting off though. all i had to do to get it to start was reset the ECU. let me know what you find
Old May 9, 2005 | 06:38 PM
NitrousFed900's Avatar
Default Re: (integrator43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrator43 &raquo;</TD></TR><TR><TD CLASS="quote"> let me know what you find </TD></TR></TABLE>
Werd! I wanna know also cause i just bought a 929 about 3 weeks ago.
Old May 9, 2005 | 07:05 PM
big pete's Avatar
Default Re: (NitrousFed900)
you have a power commander? I've heard of PC's failing which cause the bike to die
Old May 9, 2005 | 11:30 PM
.Ash's Avatar
Default Re: (big pete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big pete &raquo;</TD></TR><TR><TD CLASS="quote">you have a power commander? I've heard of PC's failing which cause the bike to die </TD></TR></TABLE>
especially common with earlier versions of the 600rr pc3.
Old May 10, 2005 | 06:29 AM
Default Re: (usdmPC3)
Yes I do have a power commander Maybe I should get it checked out. I want to at least dyno tune it soon to see what the maps are....It may be running on a different map than what it's suppossed too.
Old May 10, 2005 | 06:55 AM
Luke's Avatar
Default Re: My 929RR shutoff on Freeway!!Yikes! (GearSpeedEF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF9 &raquo;</TD></TR><TR><TD CLASS="quote">I was cruising about 80mph on the freeway...not far from my destination and my bike shut off. I tried to start it back up and it would stay on for a bit but shut off after a few seconds. I then proceeded to remove the seat and found that some of the fuses were a bit wacky but, not completely out of place. I pushed them all back in and started the bike and viola! The bike ran perfect although it does have a little idle jump from time to time. Just wondering if anybody has experienced this problem...Kind of puzzling </TD></TR></TABLE>
Side stand cut-off?
Old May 10, 2005 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GearSpeedEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Yes I do have a power commander Maybe I should get it checked out. I want to at least dyno tune it soon to see what the maps are....It may be running on a different map than what it's suppossed too.</TD></TR></TABLE>
if you want to check the maps it is very easy, as long as you have a laptop and the cable or a PC and a very long cable
i checked my bike and the previous owner had it set on the zero map, so it was doing nothing. once i loaded the correct map there was night and day difference. very crisp throttle response, and got rid of the "richness" in the mid and top end.
Old May 10, 2005 | 08:36 AM
Yeah I def.. need to get it tuned. It bogs and sputters on the low end. That is probably the source of some of the issues...Still a fast and nice bike..just needs some fine tuning Thank you everyone for your help and suggestions!
Old May 10, 2005 | 11:14 AM
i checked my bike and the previous owner had it set on the zero map, so it was doing nothing. once i loaded the correct map there was night and day difference. very crisp throttle response, and got rid of the "richness" in the mid and top end.</TD></TR></TABLE>
could you hook us up w/ this map?? lol
Old May 10, 2005 | 12:38 PM
just send me $29.99........ nah just kidding. the maps are all on the Dynojet website. each map is specific to upgrades. i.e. full exhaust, slipon exhaust, k&n filter etc.
http://www.powercommander.com
check it out free maps for everyonewith a power commander
if you want i can hook you up with the zero map for free
sorry for the thread jacking gearspeed.....
Old May 10, 2005 | 01:16 PM
sorry for the thread jacking gearspeed.....</TD></TR></TABLE>
No worries...we are all pals on here and its useful information that we can all use!!
Old May 10, 2005 | 06:39 PM
tmkpres's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmPC3 &raquo;</TD></TR><TR><TD CLASS="quote">
especially common with earlier versions of the 600rr pc3. </TD></TR></TABLE>
i know all to well about that, taking mine off in a week or so.
Sinche
Honda Motorcycles
Apr 1, 2005 09:37 AM
Newkdog
Honda Motorcycles
10
Jul 5, 2004 05:54 PM
Frito1
Honda Motorcycles
13
Dec 21, 2003 03:36 AM
fluke702
Honda Motorcycles
21
Jul 8, 2003 02:17 PM
allmotorEG-SI
Honda Motorcycles
Jun 15, 2002 04:20 AM
