Pusher Fan?
Old May 9, 2005 | 01:27 PM
jthelman's Avatar
Default Pusher Fan?
I'm nearing the end of my turbo build. I decided to go air/water IC, and I have much more room between the radiator and the bumper than between the rad and the engine block.
From what I can tell from specs, pusher fans require more amps to run, but is there anything else I might run into with this setup?
Thanks.
Old May 9, 2005 | 01:32 PM
tgreaves's Avatar
Default Re: Pusher Fan? (jthelman)
I dont see why they would require more amps to run.. I am running a 10" pusher fan on my setup right now and it works great..
Old May 9, 2005 | 03:14 PM
jthelman's Avatar
Default Re: Pusher Fan? (tgreaves)
I'm just quoting the amps listed on the fan pages for Summit, etc.
The same size fan almost always requires more juice as a pusher.
I have no idea why.....
At least you seem to have no problems, so that's good to hear!
BIG LUIS
Jul 31, 2014 07:49 PM
KevinEF7
Dec 7, 2012 12:17 PM
f22a1 ftw
Aug 7, 2010 04:57 PM
91EF919
Apr 4, 2009 12:12 PM
