moonroof problems
Old May 9, 2005 | 01:14 PM
byronl's Avatar
Default moonroof problems
ok when i try to raise or move the moonroof it makes this grinding sound and i can only raise the moonroof when i push on it. Now the moonroof doesn't want to move all the way back, it just gets stuck, I tried manually doing it and it does move but when i try to close it, it seems like it's slipping or something. help?
edit: one side moves but the other doesn't when trying to close.
Old May 10, 2005 | 12:13 AM
hatch34's Avatar
Default Re: moonroof problems (byronl)
just lube that bitch up it will be fine
Old May 24, 2005 | 07:10 AM
rdaggett's Avatar
grease that bitch up!!!!
Old May 24, 2005 | 07:18 AM
Morning Call's Avatar
my 93 si did the same kinda (no grinding)
i managed to find that the recoil spring or whatever was jamming it up.. i cut it off and it closes now.. but my motor is dying so i gotta give it a lil shove and itll go back
Old May 24, 2005 | 07:57 AM
byronl's Avatar
Default Re: (Morning Call)
what grease should i use? any kind of grease from any auto parts store or is there a particular grease to use. thx.
Old Mar 5, 2006 | 04:32 PM
elsmiles's Avatar
Default pass side of the moonroof is slower to move than the driver side of the moonrf.
I wonder if I have the same problem, but i got a 93 HB si. When i open the moonroof I notice the passenger side goes a little slower than the driver side. I've lubed it up the butt, but it still does the same thing. The worst part is when I try to close it cuz the driver side will go down but the pasnger side gets stuck and I gotta push it down to shut it. any ideas as to how to fix this timing problem? All the parts seem to match and look ok. I can't find anything broken, just the timing between the two sides.
Please help!
Old Mar 5, 2006 | 04:35 PM
usdmEHboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call &raquo;</TD></TR><TR><TD CLASS="quote">my 93 si did the same kinda (no grinding)
i managed to find that the recoil spring or whatever was jamming it up.. i cut it off and it closes now.. but my motor is dying so i gotta give it a lil shove and itll go back</TD></TR></TABLE>
did you have to take out your headliner to get to the motor?
Old Mar 6, 2006 | 10:52 AM
elsmiles's Avatar
Default Re: (usdmEFboy)
no, i didn't take the whole thing off, just enough to look and see if anything looked out of the oridinary. Where's the recoil spring?
Maybe I should tell you how it got messed up. I was cleaning the moon roof and noticed that one side would sit closer to the front of the opening when it was closed and I wanted to make it more balanced so i took it off and tried to adjust it, but I went stupid and in thinking I had screwed on the bolts in place I tested the moonroof and by the time I realized it was not in place, the moonroof had fallen to one side placing more pressure on one side, but just enough to make a difference in one side's timing.
So in essence, I am looking to see how to re-adjust it. As for the recoils, will i have to take the headliner off? Is there any way to look at the recoils by just tking the moonroof off? I am guessing it has to do something with what is motioning the moving foundations for the moonroof but i am not sure beyond that.
Any ideas would help!
jdmNit
Mar 3, 2011 07:25 PM
ahtublao
Jan 19, 2010 05:37 PM
Krash Enbyrn
Jun 4, 2008 07:36 AM
OoHiTzToMMy
10
Oct 16, 2003 06:37 AM
CivicHB-Si
Jul 21, 2002 09:24 AM
