uneven spark plugs
like it says 2 spark plugs have tons of gas on them, 1 has some gas, and 1 looks like it was partly glazed and didnt get enough fuel, when i took them out to check. would this be from faulty ignition timing. also does anybody know how to time a cars ignition without timing marks, i know theres got to be another way, since i dont want to have to keep buying plugs and having the same problem since thats the only thing i have to tune.
were they gapped properly, and all at the same settings?......i guess could be bad timing (cams), but since timing works across all 16valves at once, and not each combustion chamber seperatly, by logic id think it would be similar wear in all 4 plugs, so ovbiously either the injectors arent spraying right, or the spark plugs arent firing at the right time...are the wires, cap and rotor all newish/in good shape?
the wires and such are in good shape, i have msd 8.5s as some of you know they have a little trouble on the distributor end. anyways its highly possible that the injectors arent working right, but what should i do to check that? im going to go get some new plugs and time the ignition from there. also i have stock ef injectors that i could put in my si. would this make a difference, also its a stupid question but how would you lower your cars fuel pressure, i have an adjustable fpr that came with my car, and a pressure gauge.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous »</TD></TR><TR><TD CLASS="quote">Is this car an Accord?</TD></TR></TABLE>
Ferrari
Ferrari
:-) IS THIS CONFUCIOUS OR CONFUSED??? IT IS AN ACCORD FORUM SO 1 WOULD THINK IT IS AN ACCORD HOWEVER THEY SHOULD SPECIFY YEAR AND MODEL ...THAT SHOULD BE THE VERY FIRST THING WHEN SUBMITTING A POST IT WOULD MAKE IT SO MUCH EASIER FOR PEOPLE WHO ARE TRYING TO HELP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">:-) IS THIS CONFUCIOUS OR CONFUSED??? IT IS AN ACCORD FORUM SO 1 WOULD THINK IT IS AN ACCORD HOWEVER THEY SHOULD SPECIFY YEAR AND MODEL ...THAT SHOULD BE THE VERY FIRST THING WHEN SUBMITTING A POST IT WOULD MAKE IT SO MUCH EASIER FOR PEOPLE WHO ARE TRYING TO HELP
ive seen dumber, dont doubt HT, and, the guy's name is whiteCRX, and then, he speaks of EF injectors, that is what i gathered with no other data given. Are you Confused?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .bagged »</TD></TR><TR><TD CLASS="quote">
Ferrari </TD></TR></TABLE>
Ferrari make horrible engines, but Pininnfarina design the nicest cars!
Please, don't type in caps... It's a pain in the *** to read.
And as Confuc1ous said, talked about putting EF injectors in his SI...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitecrx »</TD></TR><TR><TD CLASS="quote">o sorry i went to a recent topic and i guess i posted in the wrong forum, sorry and thanks for all your help i think i figured it out
CRXCRAZYD16Y8
Feb 27, 2006 06:21 PM
