where to get Techedge 1.0 cable for O2 sensor??
I just bought a TE 1.0 with no O2 sensor cable, anyone know where I can get the cable? On their website they want $100au which is a little expensive anyone got one or know where to get one for cheaper????
TIA
TIA
You can just make one yourself... the O2 sensor connector can be cut from an OBD1 engine harness (has a plug in it near driver's shock tower).
its this cable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">You can just make one yourself... the O2 sensor connector can be cut from an OBD1 engine harness (has a plug in it near driver's shock tower).</TD></TR></TABLE>
One plug is from the O2 but the other is like keyboard plug with 7 pins in a circle and 1 in the center. VX civics are kind of hard to find and i dont have the pinouts on the techedge unit.
Yeah you can order just that connector from the guy if you want to save money. You can look the pinouts up online.
Before they came with the cool cases + connectors, I had to make my own:
http://iserve.honda-tech.com/i...t=181
Then when the cool case came out, I just bought the case and swapped it. (page 2)
You can actually see the pinouts in my pictures if that helps.
civictypenos
May 9, 2003 01:03 PM
