need help on zc rebuild
Old May 9, 2005 | 12:11 PM
ssbpturbohatch's Avatar
Default need help on zc rebuild
my buddy has a zc motor he's working on for a customer and needs to know how to go about getting the correct parts. He needs to replace the headgasket, rod bearings/main bearings, and the rings. Can he get them at an autoparts store? Being that its the jdm zc, what parts would he ask for, someone told him that parts for a 88-89 teg would interchange. Is that correct?? Any info is helpful.
thanks
aaron
Old May 9, 2005 | 01:23 PM
Default Re: need help on zc rebuild (ssbpturbohatch)
anyone??????
Old May 9, 2005 | 06:49 PM
minimesleeper94's Avatar
two zc engines. one is the sohc vtec which is the d16z6 offered in the 92-95 civics or the dohc which is the d16a1 from an 86-89 integra here in us, but nearly identical in every aspect but casting code, cams and ecu with different maps. go with oem. honda has the best quality compared to the auto parts stores.
Old May 10, 2005 | 04:41 AM
Default Re: (minimesleeper94)
with his being the older jdm version stamped "zc", i was not sure if the older d16a1
from the 86-89 teg would work or not. thank you for your help
Old May 11, 2005 | 05:23 PM
ZCpower91's Avatar
If it's a DOHC ZC the '89 Integra kit will work. I know this because I just totally rebuilt mine. The only thing in the kit that won't work is the seals that go on the studs that hold the valve cover down due to the Integra valve cover bolting up different than the ZC.
-DOHC ZC .020 over, Eagle Rods, Endyne 11:1 Pistons, Crespo Stage 4 Cams
Old May 13, 2005 | 05:53 PM
WestCoRacer's Avatar
Default Re: need help on zc rebuild (ZCpower91)
The D16 bearings will work in the ZC
Ken99287
68
Feb 23, 2011 09:32 AM
crxboi90
Jul 3, 2009 09:59 PM
MonsterRex
12
Dec 19, 2008 02:56 PM
scdarksol
12
Jan 31, 2004 06:38 AM
Rob_hoody
Apr 30, 2002 06:18 PM
