Dynoed yesterday, Stock B16 - 206whp / 167lb/ft @ 6.5psi
Hallo,
we had one of our customer's cars on the dyno yesterday.
Setup:
Garret T28 Turbo @ 6.5psi
100% Stock B16A1
2,5" Exhaust with racing cat
450ccm Injectors
Stock ECU based software ems (very similar to the old Hondata Stage 1-3 systems)
Here are the dyno sheet:
i think the boost level is lower then 6.5psi because the very inaccurate boost gauge was the only measurement we had on the dyno... mine in my car (have the same) shows allways 1-2psi higher then the map sensor and i think we had some ignition problems due to an old distri at high rpms.
comments welcome...
Setup:
100% Stock B16A1
450ccm Injectors
comments welcome...
Sr420Det
Engine Management and Tuning
20
Sep 1, 2010 03:28 PM
