Low oil pressure in d16z6
Old May 9, 2005 | 11:24 AM
Soccerking3000's Avatar
Default Low oil pressure in d16z6
Okay so yesterday i installed my oil pressure guage and everything was great, today i swapped out my oil pan because by other one was slightly dented. The new pan i put on is slightly different but all the bolts lined up and so did the gasket. Imade sure that that oil pick-up was clean before putting the new pan on.
Now i go to drive it and the max oil pressure i get is 30psi, what could cause this, could the pickup be touching the bottom of the oil pan? There are no leaks everything was torqued to spec i dont know what to do i cant drvie it cause its boosted and boost+low oil pressure=boom so help me out guys
thanks
Old May 9, 2005 | 11:56 AM
Default Re: Low oil pressure in d16z6 (Soccerking3000)
anyone?
Old May 9, 2005 | 05:51 PM
wow, no one?
Old May 9, 2005 | 06:11 PM
rainforest's Avatar
just buy the right oil pan iam sure thats the problem what pan is it?
Old May 9, 2005 | 06:38 PM
Default Re: Low oil pressure in d16z6 (rainforest)
its the same pan for a d16z6...
drlagares
Engine Machining & Assembly
Apr 15, 2016 09:41 AM
(760)doogie
Aug 7, 2008 02:58 PM
sohcT
May 9, 2008 06:39 AM
EJ1 wilcox
Oct 12, 2006 03:52 PM
Chris83179
Aug 19, 2002 06:12 AM
