whats the diff. between a d16z6 and a d16y8?
Old May 9, 2005 | 06:49 AM
dertymatt's Avatar
Default whats the diff. between a d16z6 and a d16y8?
shouldnt there be a code somewhere on the head and if so what should it say if it is a z6?
Old May 9, 2005 | 07:12 AM
jdmjohnny's Avatar
Default Re: whats the diff. between a d16z6 and a d16y8? (dertymatt)
the code is oin the block it will say d16z6 or d16y8..z6 is found in 92-95 civic and y8 is found in 96-2000 civic both ex models..
Old May 9, 2005 | 08:00 AM
dertymatt's Avatar
so nothing on the head it self to tell me wich one it is?
Old May 9, 2005 | 08:38 AM
AutoXer's Avatar
Default Re: (dertymatt)
The Z6 will have VTEC on the valve cover, while the Y8 will just say Honda.
Old May 9, 2005 | 08:43 AM
JDMlyfestyle's Avatar
Not true. My 100% stock 94 ex with z6 said honda on the valve cover.
the y8 has a nicer intake manifold.
Y8 has stronger steel shift forks in the transmission while the z6 has aluminum which is very proned to break over the y8 forks.
the z6 is OBD1
the y8 is OBDII
I believe the y8 has a slightly higher compression by .2
Old May 9, 2005 | 08:52 AM
GetawayInMoscow's Avatar
Default Re: (JDMlyfestyle)
Z6 has a better intake manifold or something too. I think either Ricey or Bauley know all the answers to this.
Old May 9, 2005 | 09:20 AM
''s Avatar
y8 have bigger/better manifold than z6...
Old May 9, 2005 | 09:27 AM
dertymatt's Avatar
http://www.tamparacing.com/for...32485
so ummmm i saw this and im pretty sure its a z6 but im still stumped as to why the vavle cover isnt fitting...someone please tell me why!!!
Old May 9, 2005 | 09:53 AM
dertymatt's Avatar
bumpity bump
thatseemslegit
Aug 30, 2015 01:45 PM
radicaled434
Apr 26, 2008 12:49 PM
TehMoonRulz
May 30, 2005 08:51 AM
al3e
17
May 4, 2004 11:44 AM
ATS*VEEE
20
Nov 3, 2002 09:57 PM
