jumpy speedo on auto 94 hatch
Old May 9, 2005 | 06:01 AM
dip-set's Avatar
Default jumpy speedo on auto 94 hatch
just recently i noticed the speedo not moving when going up tp 30 mph then suddenly jumping up tp about 60 when going 40 and like a 100 when going 60...
coincidentally this started happening on my way to have my headgasket, water pump, timing belt, t-stat, replaced this past saturday...
i searched the threads and see most say to check the connection at the vss, is this in the same location as the manual tranny, or can it be another possible problem being its an auto...
thanks
Old May 9, 2005 | 06:15 AM
h22 booster's Avatar
Default Re: jumpy speedo on auto 94 hatch (dip-set)
if you have aftermarket EL-guages layed over you cluster there may be friction between the needle causing it to not move continuously. It also may just be stuck, for some other reason physically.
Old May 9, 2005 | 06:17 AM
edo3276's Avatar
the circuit that runs the speedo is shot. its the circuit board right behind the speedo guage inside the cluster.
Old May 9, 2005 | 06:20 AM
dip-set's Avatar
Default Re: jumpy speedo on auto 94 hatch (h22 booster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 booster &raquo;</TD></TR><TR><TD CLASS="quote">if you have aftermarket EL-guages layed over you cluster there may be friction between the needle causing it to not move continuously. It also may just be stuck, for some other reason physically.</TD></TR></TABLE>
no rice gauges
and what if its just a bad connection , or dirty/corroded connection at the vss, how can u be so sure its a bad cluster?
Old May 9, 2005 | 06:23 AM
edo3276's Avatar
best thing to do is borrow a working cluster and plug it in. I've fixed numerous speedos with the same problem and its always been the circuit board. hope this helps.
Old May 9, 2005 | 06:29 AM
dip-set's Avatar
Default Re: jumpy speedo on auto 94 hatch (edo3276)
ok, is the cluster as easy to remove as it is in an integra ? or does the dash have to come out in the eg hatch to get the cluster out?
Old May 9, 2005 | 06:35 AM
JDM SLICK's Avatar
it's the main symptom that your VSS is about to go out...
Old May 9, 2005 | 06:38 AM
patastinky's Avatar
Default Re: (JDM ***)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM *** &raquo;</TD></TR><TR><TD CLASS="quote">it's the main symptom that your VSS is about to go out...</TD></TR></TABLE>
you got PMZ dip set
Old May 9, 2005 | 06:42 AM
it isn't too difficult. You need to unscrew a few screws (i think 3). Then pop the bezel dash piece out. It takes up a large area of the dash. Then you will remove the 4 screws that hold in the cluster. I hope I'm not missing anything but you get the gist. Just make sure you get out all the screws before you start prying the clips out.
When you do get it out. I'd lightly move the needle through the range of different mph with my finger. If it feel unobstructed, it probably due to some other electrical problem. Try replacing the cluster if possible.
Old May 9, 2005 | 06:50 AM
dip-set's Avatar
yup thats just like on a integra, thanks for verifying the steps...
Old May 10, 2005 | 05:44 AM
dip-set's Avatar
boy cars are funny, the thing fixed itself, my girl drives the civic and she called me yesterday at work to tell me the speedo was working like it normally should...
Old May 10, 2005 | 07:22 AM
ProjectEGSiR's Avatar
If it acts up again, check you distributor it started to do that in my hatch at first when i did a b16 swap the MPH started jumping around when ever it wanted too. The RPM Gauge starts joining the MPH gauge in the jumping . Then jumping will be followed by your car stumbling and shutting off. A worn Coil will do that to you.
Old May 10, 2005 | 09:17 AM
dip-set's Avatar
Default Re: jumpy speedo on auto 94 hatch (BLACK3drEG-GSIR-R)
thanks
Old May 10, 2005 | 09:18 AM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dip-set &raquo;</TD></TR><TR><TD CLASS="quote">boy cars are funny, the thing fixed itself, my girl drives the civic and she called me yesterday at work to tell me the speedo was working like it normally should...</TD></TR></TABLE>
bad ground!!!!
Old May 10, 2005 | 09:48 AM
dip-set's Avatar
Default Re: jumpy speedo on auto 94 hatch (The Internet Tough Guy)
which ground tough guy?
Old May 10, 2005 | 09:53 AM
any one of them.
Old May 10, 2005 | 10:04 AM
dip-set's Avatar
any one of which ones?
Old May 10, 2005 | 11:18 AM
the grounds in your engine bay. there's one on the tranny, one on the thermostat housing, one on the power steering pump, and there might be a few others in there i'm not sure.
Old May 10, 2005 | 12:34 PM
dip-set's Avatar
ok
Voodoo7
11
Mar 25, 2012 05:58 PM
_Keith_
Jan 1, 2007 04:02 PM
pK1spooled
Oct 2, 2004 01:24 PM
civicsitek GanGsTa
Jan 22, 2004 03:43 PM
advance concepts
May 19, 2003 01:14 AM
