should i turbo the d16 or go with the swap???
Old May 9, 2005 | 05:16 AM
RDOG39's Avatar
Default should i turbo the d16 or go with the swap???
i have a d16y8 with 133,000 miles... should i jus buy another d16 with less miles and get a greddy turbo or something thas cheap or should i do a b16 or gsr swap? im on a pretty tight budget too. which swap would be best?
Old May 9, 2005 | 05:17 AM
CivicEX96's Avatar
Default Re: should i turbo the d16 or go with the swap??? (RDOG39)
if your on a tight budget, d-series turbo is the best way to go
just make sure you do it right the first time...
Old May 9, 2005 | 06:11 AM
hondainspired's Avatar
Default Re: should i turbo the d16 or go with the swap??? (CivicEX96)
what this guy said ^^^^ ...... big fan of D-series myself...
Old May 9, 2005 | 06:16 AM
Accel Junky's Avatar
I would prefer the swap. You may not be boosted now, but you will have a better basis to start with when you do.
Old May 9, 2005 | 06:19 AM
91integraLSVTEC's Avatar
do a compression test on your engine, if it comes out good, turbo that sheeit. i recently installed a greddy turbo kit on my d16z (140k miles 200psi compression test), best bang for the buck mod!! for what it is, this set up haul's ***.
Old May 9, 2005 | 06:54 AM
canis's Avatar
i do have to say i love my turbo D16Y8 i havent had a prblems since i got it... well except i keep buring tires... but im working on it... but the turbo d16 is one of the best cars ive driven yet... my freind has got a gsr in his 93 hatch and i kick the **** out of it after the turbo spolls and everything... it a great and vary fun car.. just turbo the d16...
Old May 9, 2005 | 07:10 AM
TallAssFilipino's Avatar
Default Re: should i turbo the d16 or go with the swap??? (91integraLSVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91integraLSVTEC &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test on your engine, if it comes out good, turbo that sheeit. i recently installed a greddy turbo kit on my d16z (140k miles 200psi compression test), best bang for the buck mod!! for what it is, this set up haul's ***.</TD></TR></TABLE>
How much did you pay for your GReddy turbo kit tho?
Old May 9, 2005 | 07:15 AM
fms1day's Avatar
Default Re: should i turbo the d16 or go with the swap??? (MDJ IKNJ)
SOHC Turbo My brother has a Turbo D-Series and smokes B-serie swaps all day...
luuisss
Jan 17, 2012 09:35 AM
shutuprichard551
26
Aug 14, 2009 07:11 PM
BrianDelSol
13
May 14, 2004 06:39 AM
spock_rocker
May 15, 2003 06:28 PM
