rear lca shock bolt destruction via dremel?
Old May 9, 2005 | 04:08 AM
CaptivaBlue's Avatar
Default rear lca shock bolt destruction via dremel?
As usual, this particular bolt is locked up tight. I bought some new LCAs last night online because I figured I didn't want to deal with the stockers after this ordeal. My question is this: is there a Dremel attachment capable of cutting the head off this bolt? I've been wanting to buy my own Dremel for ages and this would prompt me to charge one today. They've been helpful doing all sorts of stuff in the past but I've never used one to cut through this much metal. I don't know if they are powerful enough. I just want to cut the bolt out and be done with it, bolt on and my blingish LCAs and non-blingish coilovers and drive.
Old May 9, 2005 | 06:29 AM
tgreaves's Avatar
Default Re: rear lca shock bolt destruction via dremel? (CaptivaBlue)
Your going to be there for a while with a dremmel.. I had the same thing happen to me and I used a wizard cutting wheel to get the nut off of my trailing arm..
jweezy225
Nov 1, 2004 02:38 AM
IWearMyKswiss
Mar 15, 2004 05:16 AM
B18G
Jan 6, 2004 08:48 PM
logictron2000
15
Apr 24, 2003 08:59 AM
Matt B
Apr 20, 2003 07:12 PM
