Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
After market toe adjustor for rear trailing arm
Old May 8, 2005 | 11:09 PM
PURPLETERROR aka BIGMATT's Avatar
Default After market toe adjustor for rear trailing arm
Can anyone recomend a good toe adjuster kit for the rear of a 91 civic si? the only thing i have found is made by spc, and seems to be overpriced. Thankyou for any recomendation or links
Old May 9, 2005 | 08:06 AM
solorexer's Avatar
Default Re: After market toe adjustor for rear trailing arm (PURPLETERROR)
how much does the spc kit retail for?
Old May 9, 2005 | 08:07 AM
Jaker's Avatar
SRR make one as well.
Old May 10, 2005 | 09:22 PM
solorexer's Avatar
We have some extra prototype pieces we made during a production run for our E Prepared SCCA race car that I would be willing to sell to anyone interested. I'm not sure what other companies making these pieces charge, but I could sell the remaining rear toe links I have for $175 for a set w/ rod ends. I am not able to get any kind of deal on the rod ends, so I would sell the machined pieces alone for $130, and let the buyer obtain the 1/2" L+R hand rod ends themselves if there was interest in that...
We also have a few left over prototype delrin lower front damper pivots. I have a few left that I would be willing to sell to anyone interested in a set. They should work on any 88-91 Civic or CRX and include the delrin bushings and hardened steel pivots. $45 a set for anyone interested...........
Old May 10, 2005 | 10:00 PM
mike-y's Avatar
Default Re: After market toe adjustor for rear trailing arm (solorexer)
prosuspension.com has the spc ones for $145 a pair
http://www.prosuspension.com/p...d=436
Old May 10, 2005 | 11:00 PM
Tyson's Avatar
Default Re: After market toe adjustor for rear trailing arm (mike-y)
has anyone considered the difference between adjusting compensator arm LENGTH and PIVOT POINT.
adjusting both changes static toe, but with an adjustable arm, youre changing the length. it changes the lever ratio which i believe affects the dynamic toe curve. adjusting the pivot point, just moves the arc but doesnt change the arc.
im sure its nice to be able to adjust both for the sake of changing the rear suspension geometry, but i think it would be a bad oversight to consider an adjustable toe link (compensator arm) as an easier way to adjust rear toe.
maybe im wrong tho. multilink rear suspension is kinda confusing to me...
Old May 11, 2005 | 12:28 AM
rsca_crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solorexer &raquo;</TD></TR><TR><TD CLASS="quote">We also have a few left over prototype delrin lower front damper pivots. I have a few left that I would be willing to sell to anyone interested in a set. They should work on any 88-91 Civic or CRX and include the delrin bushings and hardened steel pivots. $45 a set for anyone interested...........
pm
Old May 11, 2005 | 05:47 AM
solorexer's Avatar
Default Re: After market toe adjustor for rear trailing arm (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">has anyone considered the difference between adjusting compensator arm LENGTH and PIVOT POINT.
adjusting both changes static toe, but with an adjustable arm, youre changing the length. i believe affects the dynamic toe curve. adjusting the pivot point, just moves the arc but doesnt change the arc.
You are correct. Using these arms allows adjustment to rear bump steer to an extent. A longer overall arm length produces less toe change throughout suspension movement while a shorter arm length produces more change. The beauty of these adj links is that you can set the inner pivot to either extreme of the slot in the chassis or anywhere in between to alter the overall length of the compensator arm.
Spend some time on an alignment rack and change the length of the arm, then move the rear suspension throughout its range of travel and you will see first hand the changes that it makes! What is best is completely dependant upon personal preference of handling characteristics of your car, but this is one more way to fine tune the way your car feels in transitional maneuvers.
Old May 11, 2005 | 05:56 AM
CRX Lee's Avatar
I just installed a set made mny years ago by Suspension Techniques. I bought them long ago from an engineer who worked there. I don't know if they are still available.
As mentioned above, I installed mine with the inner pivot bolts in the furthest possible point to the center of the car so the arm becomes the longest and thus in theory the dynamic change should be the least but I don't recall how much length or functional effect this will have . Off the top of my head, it might be about 3/4 inch in length.
Old May 11, 2005 | 05:59 AM
.RJ's Avatar
.RJ
Default Re: After market toe adjustor for rear trailing arm (CRX Lee)
Are these "IT" legal?
Old May 11, 2005 | 06:06 AM
solorexer's Avatar
Default Re: After market toe adjustor for rear trailing arm (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Are these "IT" legal?</TD></TR></TABLE>
I dont believe so. If I remember right, you can change the bushing to spherical types, but you cannot replace the entire arm. Meaning you could use spherical bearings in the stock compensator arms, but not replace them with a completely different arm like these.
Old May 11, 2005 | 03:56 PM
CRX Lee's Avatar
Nope, but they are F Prod legal.
Old May 11, 2005 | 10:10 PM
Thanks for the info, i need to replace these soon, as the bushings in my stock arms are toast
uberhaulin
Oct 16, 2006 02:26 AM
null.
Jan 27, 2005 09:59 AM
rambler
Feb 29, 2004 02:05 AM
thelate1
Dec 16, 2003 05:55 PM
euclid
Sep 7, 2003 09:25 PM
