CRX with LS swap pulling code 14
Old May 8, 2005 | 09:47 PM
milruner's Avatar
Default CRX with LS swap pulling code 14
Been tying to figure this out for my buddys Crx for a while know and cant fix it. I used to own the car but before i sold it to him It was a 89 CRX DX DPFI, then i converted it to MPFI with a SOHC in it. Sold it to him later down the road he got a LS swap for his car and wanted to convert it to OBD-1 So he bought a Jumper harness from OBD-0 to OBD-1. Ever since we did this pulls a code 14 and the EACV does not turn on cant hear it click when i plug it in or unplug it changed it with 3 good known ones and still doesn't work any ideas. Owww yes and the other things it does is when you rev it past 1000 RPM all the way up to 2500 RPM it just fluxuates (think i missed spelled) up and down like crazy but after 2500 runs fine. well anything will help me out guys thanks for the help guys.
MIKE
Old May 9, 2005 | 12:33 AM
CRX_Control's Avatar
Default Re: CRX with LS swap pulling code 14 (milruner)
check the conversion harness, i heard 1 out of 500 chances that a harness could have misplaced pin accidentally by the people putting it together, this was what happened to mine . Send the harness back and let them check it to make sure it works, where did you get your harness btw?
Old May 10, 2005 | 10:49 PM
milruner's Avatar
bump, and thanks for the info crx-control.
MIKE
Old May 11, 2005 | 03:12 AM
4DRCIVICB18A's Avatar
that cant be the problem i have the the same motor and swap and my car does the same exact thing i can not figure it out.
hndakd
11
Jun 14, 2012 10:07 AM
sikciv666
Jul 15, 2007 07:45 AM
milruner
May 12, 2005 05:15 AM
milruner
May 10, 2005 10:50 PM
