WTB: Aftermarket ICV
Old May 8, 2005 | 09:29 PM
killa_lude's Avatar
Default WTB: Aftermarket ICV
I'm looking for a universal aftermarket ICV. Make offer. PM me, post or email me at bleeding_internally@hotmail.com
Old May 9, 2005 | 09:56 AM
killa_lude's Avatar
Default Re: WTB: Aftermarket ICV (killa_lude)
up
Old May 9, 2005 | 01:56 PM
VRD^don's Avatar
bumps
Old May 10, 2005 | 04:19 PM
killa_lude's Avatar
Old May 11, 2005 | 09:54 AM
killa_lude's Avatar
up up up
Old May 11, 2005 | 05:16 PM
VRD^don's Avatar
bumps//
Old May 12, 2005 | 08:06 AM
VRD^don's Avatar
Default Re: WTB: Aftermarket ICV (sohc_Vtec)
bumps..this dude is desperate..
Old May 12, 2005 | 04:20 PM
killa_lude's Avatar
yes very...lol
Old May 12, 2005 | 08:51 PM
killa_lude's Avatar
up that would be great!
Old May 13, 2005 | 06:59 PM
killa_lude's Avatar
Old May 14, 2005 | 04:08 PM
killa_lude's Avatar
Old May 16, 2005 | 07:03 AM
killa_lude's Avatar
Old May 17, 2005 | 03:52 PM
VRD^don's Avatar
bumps ..anyone have one..
Old May 17, 2005 | 04:25 PM
VRD^sam's Avatar
bumps....^^^help this guy out...
Old May 18, 2005 | 09:55 AM
DaveF's Avatar
Default Re: WTB: Aftermarket ICV (ef9turbohatch)
WTF is an aftermarket iacv??
Old May 18, 2005 | 03:50 PM
killa_lude's Avatar
thanks guys
Old May 18, 2005 | 05:47 PM
DaveF's Avatar
Default Re: WTB: Aftermarket ICV (Dturbocivic)
Old May 22, 2005 | 01:28 PM
killa_lude's Avatar
If you don't have a stock manifold than most likely you will need a aftermarket IACV. I have a GE mani and w/o a IACV your car won't start up nor idle.
Old May 22, 2005 | 01:45 PM
BB6-213's Avatar
bump, I thinlk I might need one too, does anyone make an aftermarket one?
Old May 22, 2005 | 06:25 PM
DaveF's Avatar
Default Re: (BB6-213)
all you need is...
take a look at the stock idle air control motor. it has 2 holes on the part where it "butts" up against the intake manifold. the function of these holes is to bypass the throttle plate when the engine is cold to help it warm up.
i can make you adapter plates (billet aluminum.) which bolt to the stock idle air control bracket, and also have threded holes for npt push to connect/barbed style hoses, all you need to do is put one side of the hose before the throttle plate, and put the other hose to the othe side of the thottle plate, and your car will idle like its stock.
Old May 22, 2005 | 06:49 PM
BB6-213's Avatar
Default Re: (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">all you need is...
i can make you adapter plates (billet aluminum.) which bolt to the stock idle air control bracket, and also have threded holes for npt push to connect/barbed style hoses, all you need to do is put one side of the hose before the throttle plate, and put the other hose to the othe side of the thottle plate, and your car will idle like its stock.</TD></TR></TABLE>
do you have a pic of the adapter plate, because I am just having a hard time figuring this out, sorry
Old May 23, 2005 | 07:02 AM
DaveF's Avatar
sorry i dont have any pics of it.
Old May 25, 2005 | 01:52 PM
killa_lude's Avatar
so you have a plate that goes to the stock IACV and then you just run lines to the aftermarket manifold? Because isnt it ran by the ecu? Because coolent controls the opening and closing of the valve correct?
Old May 25, 2005 | 03:36 PM
BB6-213's Avatar
bump
Old May 25, 2005 | 07:54 PM
DaveF's Avatar
Default Re: (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">so you have a plate that goes to the stock IACV and then you just run lines to the aftermarket manifold? Because isnt it ran by the ecu? Because coolent controls the opening and closing of the valve correct?</TD></TR></TABLE>
right.
the temp of the engine depends on how far the ecu opens the iac to control the idle.
