Need help with identifiing engine noise!!!!!!!!!
Old May 8, 2005 | 05:18 PM
DaveSi677's Avatar
Default Need help with identifiing engine noise!!!!!!!!!
So I was driving at about 90 Km/H and this douche bag just come up to my rear bumper and nearly hits me. The thing is that I get a bit nervous because of when I got rear end by motorcycle. So I tried to downshift but I mist third gear and the car staid in neutral but I kept my foot on the gas as I was trying to change lanes. Right away after at about 3000 rpm I here this noise like clak clak clak. So I pull over and pop the hood. When I would give it some gas I would here the same clak clak clak but from inside the valve cover and I could feel it abit too. The thing is that I can drive it but when I tried hitting VTEC it would become worst so I stopped that right away and babied the car home at about 30 km/h.
So what would be the worst case scenario or something that can be easily fixed. Btw its a D16Y8.
Ps: if you need more info just ask ill answer back right away
Dave
Old May 8, 2005 | 05:34 PM
DaveSi677's Avatar
Default Re: Need help with identifiing engine noise!!!!!!!!! (93SiVtec677)
come on
Old May 8, 2005 | 05:37 PM
civictildeath's Avatar
check timing. could have jumped time and the noise is valves hitting the pistons.
check valve clearence and cam shaft lobes for wear
check oil
Old May 8, 2005 | 05:39 PM
civic_fan's Avatar
Default Re: Need help with identifiing engine noise!!!!!!!!! (civictildeath)
I had an engine that made that noise.....my connecting rod had broken and the piston was hitting the valves
Old May 8, 2005 | 05:40 PM
DaveSi677's Avatar
Default Re: Need help with identifiing engine noise!!!!!!!!! (civic_fan)
ok when the connecting rod broke what has to be done to fix it.
Dave
Old May 8, 2005 | 05:43 PM
tear the engine down and replace it with a new one.
valve cover off, head off, oil pan off then the fun of taking the pistons out, replacing all the bearings, rods, and rings (rings just because why not) maybe need new pistons too if damaged same with valves. then putting it all back together
Old May 8, 2005 | 05:45 PM
DaveSi677's Avatar
what would be the cost of this more or less.
Plz, I know I might be annoying about it, its just that I am fucken worried about it.
Dave
Old May 8, 2005 | 06:09 PM
DaveSi677's Avatar
anymore advice!!!!!!!! plz
dave
Old May 8, 2005 | 06:11 PM
civic_fan's Avatar
as for price, id say probably around $200-300 in parts if you do it yourself....
Old May 8, 2005 | 06:12 PM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiVtec677 &raquo;</TD></TR><TR><TD CLASS="quote">anymore advice!!!!!!!! plz</TD></TR></TABLE>
don't start the car until you figure out what's going on. pull the valve cover off and have a look.
Old May 8, 2005 | 06:16 PM
DaveSi677's Avatar
Default Re: Need help with identifiing engine noise!!!!!!!!! (The Internet Tough Guy)
the thing is I have to drive it to my mechanic tomorrow. but its not to far. I will go very slow. But is there anything else I should be worried about. Could it be also be a camshaft bearing or something related to the camshaft
Dave
Modified by 93SiVtec677 at 3:27 AM 5/9/2005
Old May 8, 2005 | 06:28 PM
DaveSi677's Avatar
bump plz need more opinions.
Dave
Old May 8, 2005 | 06:55 PM
DaveSi677's Avatar
Guys I wouldnt be asking if I knew the answer but could it be camshaft related?
Dave
Old May 8, 2005 | 07:15 PM
DaveSi677's Avatar
bump
Old Jun 11, 2005 | 07:44 AM
Rabid's Avatar
I think I just had something like this happen to me. I was having a funny clunk on the last few start ups and nothing else. Only happened in the morning start. I drove to the office. Then I drove from there and got a few miles and was going about 60 when it suddenly started to make a sound like belt a wrapped around a pulley broken off and slapping. Like a wap wap wap or clak or I dunno. I nursed it back. Although it ran just fine, the noise was disturbing. It sounded like it could be coming from the valves near the distributor but it was hard to tell. It even seemed to be intermitent with rpm at idle. I'd finally desided it was the distributor bearing because the dist turned with a notching feel. I put in a new dizzy yesterday but I also worked on the timing belt and water pump. When I started it, the thing made a horrible bang bang bang like a piston strike. Shut it down and tripple checked the timing. Not the problem. Either I have the same problem still and it got worse with a cold engine or I'm just missing something... To be continued.
sacred redhead
Honda Civic (2001 - 2005)
Nov 12, 2013 08:05 AM
boarding2008
Jun 15, 2010 01:18 PM
MODsjtown
Jan 4, 2005 01:05 PM
kshymkiw83
Aug 12, 2004 11:29 PM
BryanS
Sep 25, 2001 10:46 AM
