Additional evacuation port?? How about engine oil filler cap.. (Pics inside)
Old May 8, 2005 | 05:04 PM
vtec.dc2's Avatar
Default Additional evacuation port?? How about engine oil filler cap.. (Pics inside)
total cost: $5-6 dollars
parts: oil cap + 3/8" fitting and a hose and metal hose clamp
so.. why not give it a shot.
This is vtec b series where breather is right next to oil filler cap, i tried this for 2-3 miles, but gotta feeling i may experience some oil loss because of location. i dont have any oil coming out from side port. this fitting is straight through, if it had 90 degree turn underneath the cap, it might not collect as much oil.. there was no oil spitting out at idle though..
my original plan is to add 2 extra ports on exhaust part of valve cover..
Old May 8, 2005 | 05:24 PM
mrbsponge's Avatar
ya know i was just thinking this 2 days ago, cause i didnt want to do any crazy fab work. as far as i can see it work just as good as any others
Old May 8, 2005 | 05:42 PM
h22 civic's Avatar
Default Re: (mrbsponge)
that will work just fine but it will need to be as big as posible somewhere in the 3/4" range
Old May 8, 2005 | 05:49 PM
y7turbo's Avatar
Default Re: Additional evacuation port?? How about engine oil filler cap.. (vtec.dc2)
just did it to mine .. this is a breather from autozone.. it was like 4 bucks and has kinda some baffles on the bottom so no oil goes through..
Old May 8, 2005 | 05:57 PM
DRIVENRacing's Avatar
hmm not a bad idea... just doesnt look clean
Old May 8, 2005 | 05:59 PM
R@mon's Avatar
Default Re: Additional evacuation port?? How about engine oil filler cap.. (konigturbocivic)
z10 sells this really nice banjo setup. screws right into were the oil cap used to go then gives you a nice -12 sized fitting to run w/e you want
Old May 9, 2005 | 09:09 AM
vtec.dc2's Avatar
Default Re: Additional evacuation port?? How about engine oil filler cap.. (R@mon)
haha.. i thought people would laugh at this idea.. but i guess it does the job..
say if i run oil cap and factory fitting, would that be enough so i won't need to drill for additional ports?
94ej1coupe206
14
Nov 26, 2016 10:01 PM
Budget Racer
29
Mar 29, 2008 12:05 PM
Razr2
Jan 22, 2008 09:47 AM
stareatsun
Mar 31, 2006 03:28 PM
FlipboiGSR
Aug 24, 2001 07:41 PM
