ppl with the magnetic oil drain plug
i got a magnetic oil drain plug from passwordjdm its a 14mm socket that magnetic is strong no joke...had some problems guidin it into the oil pan hole
You all are talking about the bolt head size. I believe the actual bolt size is 17mm. As in you go buy a 17mm bolt and it will work. It does not matter what the head size is on those aftermarket bolts, their still 17mm bolt just with different size heads. They’re all made to custom specs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">You all are talking about the bolt head size. I believe the actual bolt size is 17mm. </TD></TR></TABLE>
Correct about the bolt head size. But i dont think the actually drain plug is 17mm i think its 14mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg »</TD></TR><TR><TD CLASS="quote">
But i dont think the actually drain plug is 17mm i think its 14mm </TD></TR></TABLE>
No way bro, I just pulled out my engine yesterday and I know exactly what size a 14mm bolt is. The drain plug is DEFENTLY bigger.
>>>>Goes to look at helms...
>>>>Goes to look at helms...</TD></TR></TABLE>
It doesnt say a size but Autozone says it is 17mm BOLT (not just head).
If you guys are looking for the actual bolt size, not the head size... I bought an M14X1.50 drain plug bolt from CTC and it fit like a glove.
