hmt catch can for 11 dollars.
Old May 8, 2005 | 03:15 PM
hotrex's Avatar
Default hmt catch can for 11 dollars.
well i decided i dont like to pay for jdm type x slasher parts to make my car fast, so i fab everything myself. the latest adventure was this catch can,
parts are
7 inch piece of 3 inch pvc piping
2 end caps
3 1/2 inch barbed fittings
2 fittings for the clear sight tube
3 inch piece of clear tubing for sight window
a petcock
a piece of steel wool for the oil droplets to catch on
and a filter.
took me 25 mins to make it and install it, and costed 11 dollars at homo depot.
that is all
Old May 8, 2005 | 04:21 PM
nerdsports's Avatar
nice. i was contemplating doing one like that for my car...
i think i will do one now...
Old May 8, 2005 | 05:25 PM
CRXDrew's Avatar
Nice one hotsex. But 11 bucks? How much of that stuff was free/pocketed! I would think the lil filter would be atleast 5 bucks.
Old May 8, 2005 | 06:30 PM
Want2race's Avatar
Default Re: (CRXDrew)
WHat is the point of that external tube? just to show the level?
I personally must either be a shitload smarter..
I would use a Propane tank *empty one!* and just cut the top and add your filter, then drill and tap your side tube.
Cheaper option than what you have used
Old May 8, 2005 | 07:32 PM
hotrex's Avatar
Default Re: (Want2race)
its all about being creative, id hollow out your moms ***** and tap that for a fitting,
hows that
Old May 9, 2005 | 12:47 AM
Syner-G-Racing LLC's Avatar
Default Re: (hotrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex &raquo;</TD></TR><TR><TD CLASS="quote">its all about being creative, id hollow out your moms ***** and tap that for a fitting,
hows that </TD></TR></TABLE>
I think I just **** myself , but thanx for the laugh
not bad on the catch can, as far as tapping a propane tank...be careful not to blow your face off.
Old May 9, 2005 | 01:08 PM
Project99EK's Avatar
Some people...
Old May 11, 2005 | 04:36 AM
menkio's Avatar
Default Re: (Project99EK)
hmm, this or the enedny or whatever that tool is marketing now.. hmmm... hmm... i'm gonna gave to go with the hmt 11 dollar setup
Old May 11, 2005 | 07:43 AM
jolt-tsp's Avatar
Default Re: (menkio)
This guy that runs a kart at the autocross uses a empty oil quart bottle with a hose giong in it. All that costs is the hose No suction line, but it serves it's purpose of keep oil off the track.
Old May 11, 2005 | 11:50 AM
mrbsponge's Avatar
this is the EXACT way i did mine, straight from ACE tru value
Old May 11, 2005 | 11:53 AM
EJ1 wilcox's Avatar
Default Re: (mrbsponge)
Nice... mine is almost done...
Very similar but I'm using a SeaFoam canister
Old May 15, 2005 | 09:34 AM
Hatchd's Avatar
Default Re: (EJ1 wilcox)
Hey, was that my $11 that you spend on it? Just wondering since you owe me $200 or some parts for the last 7 months.
Old May 15, 2005 | 08:46 PM
hotrex's Avatar
Default Re: (JapTendencies)
Old May 16, 2005 | 06:55 AM
BigZ88's Avatar
very nice, but do you worry about the steel wool breaking down over time and possibly getting into the engine? What about using one of those shower thingys that chics use instead of a wash cloth.... you know what i'm talkin bout? Would that possibly work better?
Old May 16, 2005 | 07:06 AM
EJ1 wilcox's Avatar
Default Re: (BigZ88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigZ88 &raquo;</TD></TR><TR><TD CLASS="quote">very nice, but do you worry about the steel wool breaking down over time and possibly getting into the engine? What about using one of those shower thingys that chics use instead of a wash cloth.... you know what i'm talkin bout? Would that possibly work better?</TD></TR></TABLE>
How will it get back into the engine? The oil that ends up in the catch can is captured from vapors. It remains in the catch can until you decide to empty it. It's usually pretty nasty and shouldn't be poured back into the engine.
I have steel wool in my catch can as well..
Old May 16, 2005 | 07:15 AM
jolt-tsp's Avatar
Some of us use a line to the intake pipe off the catch can instead of a breather filter to help pull from the valve cover and PCV into the catch can (so, pcv/valve cover-&gt;catch can-&gt;intake pipe), so if the steel wool breaks down it could get sucked in the intake. I've never heard of it being a problem before, although it is a good question.
Old May 16, 2005 | 08:35 AM
BigZ88's Avatar
Default Re: (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">Some of us use a line to the intake pipe off the catch can instead of a breather filter to help pull from the valve cover and PCV into the catch can (so, pcv/valve cover-&gt;catch can-&gt;intake pipe), so if the steel wool breaks down it could get sucked in the intake. I've never heard of it being a problem before, although it is a good question.</TD></TR></TABLE>
thats why i asked.....thats how i've always seen a catch can hooked up. What is the other way?
Old May 16, 2005 | 11:28 AM
jolt-tsp's Avatar
You just put a filter on the sucking side, like in the pic at the top of this thread. In theory, the crackcase and valvecover will have positive pressure (the whole point of needing to release them). And the positive pressure should be enough to get the fluids to the catch can on their own without the aid of the other side having suction. The filter just lets the catch can breath without filling with crap.
Old May 16, 2005 | 01:44 PM
BigZ88's Avatar
ahh ok
Old May 21, 2005 | 09:30 AM
BlueShadow's Avatar
Hey guys,
I had a question for you HMT catch can guys. Did anyone use a baffling system other then steel wool? my Moroso catch can had a plate at the top with 2 louvers on the plate to let air through. I was thinking about doing a baffle setup similar to this instead of the steel wool.
Also how many of you guys used a filter with a large diameter neck instead of a filter with a small diameter neck? (similar in size to the ones you stick on your valve cover.
Old May 21, 2005 | 05:47 PM
_gurusan_'s Avatar
Default Re: (BlueShadow)
Can you please explain the process a bit more in detail...? Like a write-up or something?
I'm not 100% sure I understand the PCV system either....
Old May 25, 2005 | 04:46 PM
jedubz's Avatar
Yes hotchex! I want to see too!
Old May 30, 2005 | 03:21 PM
BlueShadow's Avatar
Default Re: (jedubz)
I wanted to bring this up one more time,
Do you guys think it would be a good idea to use a valve cover breather with a small neck? like the ones you see people putting on their valve cover nipple (5/16" dia?). I was thinking about getting a container and having my local machine shop drill and tap the sides for the ports behind the engine and drill and tap the top and stick another barbed fitting there and attaching my breather filter there.
what do you guys think?
HT Chaplain
Welding / Fabrication
Apr 26, 2007 03:42 AM
scientisthonda
Nov 22, 2004 12:20 PM
