Suspension & Brakes Theory, alignment, spring rates....
bumpy Suspension around turn...
Old May 8, 2005 | 03:12 PM
.1type.'s Avatar
Default bumpy Suspension around turn...
i do a lot of canyon driving... i just got the new falken azenis rt-615. 205/40/16. i am running JIC coilover flta2. i fight my car around a turn, it is just way to bumpy..
what do you guys think....
Old May 8, 2005 | 11:37 PM
bc_ef8's Avatar
What are your coilovers set at? spring rates? ride height?
Either your suspension is too stiff or you are too low. When you are too low it's possible that you are hitting the bumpstops.
Old May 9, 2005 | 02:33 AM
eMpAtHy's Avatar
Default Re: (bc_ef8)
bumpy as in soft bumps or hard bumps..hard bumps=means stiff *** spring rates and ur dampeners need to be set at a stiff setting to match the spring rates on your springs. if its just a constantly soft up/down bounce..your springs are WAY too soft or you blew your shocks cause it might be too low of a ride and u bottomed out ur shocks, thus blowing them.
Old May 9, 2005 | 11:07 AM
jeremy.'s Avatar
Default Re: (eMpAtHy)
get a type r then josh
Old May 9, 2005 | 11:10 AM
.1type.'s Avatar
Default Re: (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">get a type r then josh </TD></TR></TABLE>
trade me yours....lol
Old Jun 7, 2005 | 07:00 AM
gabebauman's Avatar
Default Re: (1type)
You should try some Polyurethane motor mount inserts...I installed the two front lower and my wheel hop is very minimal now. Besides...they're only $36.00
https://honda-tech.com/zerothread?id=713941
Old Jun 7, 2005 | 07:18 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">You should try some Polyurethane motor mount inserts...I installed the two front lower and my wheel hop is very minimal now. Besides...they're only $36.00
Hmmm, I must have missed the part of the thread where somebody mentioned wheel hop...
Old Jun 7, 2005 | 08:02 AM
gabebauman's Avatar
Default Re: (94eg!)
Dang...I'm just trying to help man. The link is just where I got them from...so if he's interested...he could possibly get them there too. I felt a noticable difference after I installed mine...that is all.
Old Jun 13, 2005 | 01:34 PM
Circuit Star-29's Avatar
My car is doing the same thing at the track. Bushings. Get a master kit. Should solve the problem. Maybe its the tires though as I have those also...LOL. Pretty sure its bushings.
Old Jul 17, 2005 | 03:07 PM
.1type.'s Avatar
Default Re: (C-speed Ricer)
bushings kit eh.. i am going to have to check that out.... but i think the tires have something to do with it too... i think the side walls are to hard with a 40 series tire...
blackeg
Suspension & Brakes
Sep 9, 2011 07:35 PM
dthug
Suspension & Brakes
Jan 8, 2007 07:38 PM
SilverDc2
Jun 22, 2003 04:07 PM
Henry HA
Jun 4, 2003 06:30 AM
civicboy95
Dec 28, 2002 02:03 PM
