H22 Prelude parts, OEM and aftermarket, block parts, H22a4, H22a
Recently updated, cleared the sold & added more items
I have:
Hondata Stage 4b- SOLD
Intronics Pocket Programmer (burn your own roms)- $75
JUN H22 Intake Cam (NEW)- SOLD
Type SH cams- $80
JDM H22 block with bad rings- SOLD
H22 Single Staged Intake Manifold. Been given a stage 1-2 port by Blacktrax & has 2 ported out IAB plates to increase plenum volume & top end power (dyno tested on my car to give an additional 9whp)- $225
Intake Manifold- mildly ported, but heavily modified, the EGR system is completely removed then welded over, with unused NOS Wet nozzles in place (just the bottom half)- $75
Stock H23 Intake Manifold $50
H22 Throttle bodies, stock no TPS sorry- $40
H22/Integra 64mm T-body (no tps)- $125
Greddy Header w/ 2 1/2" collector mod (dent free flex pipe in great shape) SOLD
AEM V2 (used) for H22 Ludes- SOLD
Crower H22 Rod, just one the good quality rod $70
Oil Squirters- $50
OEM Spark Plug Cover (painted black)- SOLD
Autometer Phantom Gauges (oil pressure, and boost) SOLD
Autometer Lunar series Boost gauge $40
3 gauge pod (4th gen ludes) $40
Universal 2 gauge pod SOLD
ACL std. size Main Bearings (F22, H22, H23) SOLD
MAP Sensor (firewall mounted)- $20
4th gen drivers side airbag, steering wheel, also have SRS computer.
5th gen rear ABS sensors- $15
4th gen calipers (from a 'S', fronts & rears available)- $30 a pair
4th gen front driver's side LCA $15
4th gen Cruise Control- $25
4th gen PS pump- $30
Misc AC parts, ask me
AC compressor- $35
Aluminum AC bracket- SOLD
Iron AC bracket- $10
4th gen PS Brackets-$15
Alternator Bracket- SOLD
Oil Cooler off of a H22a4- SOLD
H22 Thermostat Housing- $30
AEM Underdrive Alternator Pulley- $45
Distributor H22 external coil- $75
Alternator (no pulley)- $25
H22 obd1 345cc injectors- $80
RC 550 P&H injectors- Pending
OEM Fuel rails- $10
F23 Acura CL VSS- $60 (I have the tranny too, no guarantees on condition though it was popping me out of reverse for the 30 miles I used it, good for a someone that wants to build a long gear turbo tranny)
Misc gaskets left over from head gasket kit, ask me
I have a parts harness, so if you need any plugs, ask me
Pics:
Modified by 2lude4u at 8:02 PM 12/12/2005
I have:
Type SH cams- $80
Oil Squirters- $50
AC compressor- $35
OEM Fuel rails- $10
Pics:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBB4 »</TD></TR><TR><TD CLASS="quote">im looking for a h22 block. How much for shipping to Indiana PA 15701-thanks----Chris</TD></TR></TABLE>
Shipping will be around $100, I'll get a quote from my freight broker sometime today or tommorrow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H duce duce »</TD></TR><TR><TD CLASS="quote">radiator fans for sale? pm if so.</TD></TR></TABLE>
I do have fans and a radiator, pm sent
CD5 Sedan
I'll take some pics and answer your ?'s tonight. I have 1 & 2, maybe 4
CD5 Sedan
Thanks, My email is Cmatthews85@yahoo.com
bump.....
for not recieving the pm about the rad. fans
please pm, and/or email thesagacontinues@earthlink.com
I must of accidentally sent the pm to regarding the fans to someone else, because I know I did pm someone about them, sorry.
Yes I have some and a radiator, pm sent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dittycrac245 »</TD></TR><TR><TD CLASS="quote">do you have the down pipe and the shift linkage
Sorry no shift linkage. I have half of a Greddy downpipe after doing the 2 1/2" collector mod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyooj »</TD></TR><TR><TD CLASS="quote">pics of both the valve covers plz</TD></TR></TABLE>
Red one is sold, I'll send out a pic as soon as I can. Unfortunately that won't be until Mon or Tues since my place is getting fumigated for termites, no getting to my computer and pics right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude »</TD></TR><TR><TD CLASS="quote">do u have the spark plug wire cover?</TD></TR></TABLE>
I swear I do but can't seem to find it. A local friend has dibs on it when I do though.
