head gasket help
K so I replaced the head gasket, it still throwing a lot of white smoke. It's steam mostly but it's really thick. What else other than the head gasket could cause this problem?could the two lines of coolant behind the mpfi be leaking into the manifold/ Please help guys. Thank you!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adrian69 »</TD></TR><TR><TD CLASS="quote">K so I replaced the head gasket, it still throwing a lot of white smoke. It's steam mostly but it's really thick. What else other than the head gasket could cause this problem?could the two lines of coolant behind the mpfi be leaking into the manifold/ Please help guys. Thank you!!!
did you use new bolts? I'd recheck the compression. I re-used them on my mazda (TTY bolts just like the hondas) and my HG blew 2 days later. That or it's just burning off the old ****, good luck hope it's nothing serious
</TD></TR></TABLE>did you use new bolts? I'd recheck the compression. I re-used them on my mazda (TTY bolts just like the hondas) and my HG blew 2 days later. That or it's just burning off the old ****, good luck hope it's nothing serious
oakraidersnum1
Mar 9, 2008 01:53 PM
