Changing Filter ? ?
Old Feb 3, 2002 | 07:24 PM
you2envious's Avatar
Default Changing Filter ? ?
Ok I know its gonna be open season on my rear axle . BUT , is it fairly easy to change the autotrans fluid ? Is there just a kit I can get ? Or do I have to get a filter , a seal ? What are the specifics required to pull this one off ? Also does anyone know anything about adjusting the Valvetrain on a d16y8 EX VTEC .
Old Feb 3, 2002 | 08:14 PM
Default Re: Changing Filter ? ? (you2envious)
Anyone?
Old Feb 3, 2002 | 10:44 PM
Dr. Gonzo's Avatar
not sure about the trans fluid, but i might be able to help you with the valvetrain. What are you trying to do?
Old Feb 3, 2002 | 11:43 PM
BARF1's Avatar
Default Re: Changing Filter ? ? (D16_VTEC)
automatice tramission fluids are easy to change ...
easier then manual fluids ...
I read the fluids change in haynes a few times .. and i finish the job within 30mins .. it is very easy ....
the autotrans have no filter .. no seal ....
first ..
raise the car ...
unbolt the nut with a 3/8 square on it ..
let it drain out ...
screw the nut back in .. 36 lb/ft if you have a torque wrench .. if not .. just make sure it is tight ...
put new fluids using a funnel into the transmission through the dipstick (transmission's dip stick)
slowly move through P to D2 .. and check fluids level again ... and you are done ..
[Modified by BAR-F1, 8:48 AM 2/4/2002]
Old Feb 4, 2002 | 08:37 AM
Default Re: Changing Filter ? ? (BAR-F1)
Damn the autos have no filters? ? ? ? ? ? ? . Well thanks anyways . The valve train question is , every 30 thousand your suppose to adjust the valves . How do I go about doing that . I guess the valves are suppose to be adjusted on that mile interval . What kinda tools do I need and how long does it usually take . (Trying to get an idea of if its gonna be a all day long thing) . Also what would be a good type of ATF to use ? I know its an auto , ((wishing for manual)) but I deal with it LOL
[Modified by you2envious, 5:48 PM 2/4/2002]
Old Feb 4, 2002 | 09:26 AM
hmm any suggestions ?
Vtec04
Transmission & Drivetrain
Jun 10, 2017 01:01 PM
dk199160
Oct 23, 2015 11:54 AM
theLemur
Dec 27, 2014 01:01 PM
PoorDad
Nov 7, 2010 10:19 AM
wkdclwnz
Sep 26, 2006 03:56 PM
