Antifreeze Leak
Old May 8, 2005 | 12:23 PM
Crazysol's Avatar
Default Antifreeze Leak
The Antifreeze is leaking from behind the engine. The car is not overheating or anything. I dont think it is a blown head gasket, because there isnt white smoke coming out of the exhaust or anything like that.
I am going to have a leakdown check done today to make sure. is there anything else it could be from. Is it a bad hose somewhere or what. How many lines have Radiator fluid running though them.
Old May 8, 2005 | 12:29 PM
drdisco69's Avatar
Default Re: Antifreeze Leak (Crazysol)
There's a lot of stuff with coolant running through it on the back of the motor. Your best bet it to get a light and look around for the leak. A mirror is helpful as well.
Old May 8, 2005 | 12:32 PM
Crazysol's Avatar
Default Re: Antifreeze Leak (drdisco69)
I didnt think about a mirror. But it is so hard to see anything because the charger is in the way. I will try the mirror idea and see if anything is coming out.
Old May 8, 2005 | 12:34 PM
drdisco69's Avatar
It usually helps to get under the car, if you have ramps or a jack stand it makes it a lot easier. Do NOT get under the car with just a jack holding it up, or Darwin will kick your ***.
N0r420cal
13
Aug 25, 2013 01:18 PM
Kgill23
Aug 30, 2010 03:14 AM
xpdude
28
May 3, 2010 02:33 PM
snibbor
Feb 3, 2008 12:39 AM
Racermech
Jan 19, 2007 07:30 AM
