broken mount bolt holes on block... how to fix
Old May 8, 2005 | 10:21 AM
VtecKiDD's Avatar
Default broken mount bolt holes on block... how to fix
ive heared welded aluminum IS MUCH weaker than the casted pieces. so how would i be able to fix this?
the hols is cracked and becasue its stretched from the cracks, its oval inside.
can i weld it up and redrill/tamp a new hole, or will it be too weak to do hold the engine up after i weld?
and if it is too weak, how do you fix something like this??
Old May 8, 2005 | 03:15 PM
NJIN BUILDR's Avatar
Default Re: broken mount bolt holes on block... how to fix (VtecKiDD)
Welding aluminum,even cast aluminum,can be very strong.A lot of products are made by welding cast aluminum pieces together.I seen many stud bosses welded with great results.Welding is the way to go.
Glenn
92db2gs-r
Welding / Fabrication
May 13, 2011 12:43 PM
grjp1988
Sep 28, 2008 05:08 PM
ayougo
Jul 1, 2006 11:02 PM
gsrcivic619
Apr 8, 2004 05:30 AM
PSU-TEG
Apr 30, 2003 08:55 AM
