Interesting Wiring Problem belived
Old May 8, 2005 | 10:09 AM
my89civicstd's Avatar
Default Interesting Wiring Problem belived
Was wondering if anyone could give me some hints on finding the solution to a problem my civic is having. When I cut on the headlights the running lights and dashlights do not cut on. The headlights do work though. But everynow and then they will work. I am not sure what is causing it nor do I know where to start. At first I belive it was the dimmer so I replaced it. Then I replaced the switch for the headlights and still no change. If anyone has any advice to lead me into the right direction on finding the problem please let me know. Thank you
Old May 8, 2005 | 10:44 AM
mugenwannabe's Avatar
fuses
Old May 8, 2005 | 11:00 AM
eda6's Avatar
Default Re: (mugenwannabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenwannabe &raquo;</TD></TR><TR><TD CLASS="quote">fuses</TD></TR></TABLE>
I don't think that's the problem because..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my89civicstd &raquo;</TD></TR><TR><TD CLASS="quote"> But everynow and then they will work.</TD></TR></TABLE>
I'd look for loose wires
Modified by eda6 at 12:29 PM 5/8/2005
Old May 8, 2005 | 11:04 AM
Default Re: (eda6)
So I need to check all the fuses under the dash, and then I will start checking the wiring. Exactly which wires run the running lights and dash lights. Seems odd that all the wires that run all that would go bad. Thats why a fuse problem seems more evident.
thepipes
Feb 16, 2007 11:24 AM
speedycivicgurl
Aug 13, 2004 07:21 PM
2ksilverex
Jun 14, 2004 09:52 AM
Grease Monkey
Dec 16, 2003 08:47 AM
SaltyHatch
15
Apr 27, 2003 07:10 PM
