Resetting ECU?
Old Feb 3, 2002 | 06:35 PM
hYpE-R-29's Avatar
Default Resetting ECU?
Ya ya..i know this is a old topic, but i tried the search and nothing popped up...My question is I have never Reset my ECU after the mods I had done (JDm Header, AEM CAI, Apex N1)...my question is Should I do it?, and HOw do you do it, please tell me step by step instructions....I know this was posted before a billion times so i APologize for posting it again....Thnx
Old Feb 3, 2002 | 07:07 PM
hYpE-R-29's Avatar
Default Re: Resetting ECU? (hYpE-R-29)
Anybody??
Old Feb 3, 2002 | 07:08 PM
R#486's Avatar
New User
You should reset your ECU.
To do this disconnect the negative cable on the battery for about 5mins and then start the car and let it idle for about 5mins.
Someone correct me if i'm wrong.
Old Feb 3, 2002 | 07:22 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Resetting ECU? (R#486)
it's even easier than that...pull out the backup fuse (7.5) out of the fuse box under the hood for 10 seconds. boom, done.
Old Feb 3, 2002 | 08:03 PM
B2FiNiTY's Avatar
Default Re: Resetting ECU? (rodney)
Old Feb 3, 2002 | 09:06 PM
Art Vandeleigh's Avatar
Default Re: Resetting ECU? (B2FiNiTY)
i reset my ecu too after every mod...but i keep asking myself why?? doesnt the ecu continually check for any differences in air/fuel and adjust to them?? hat would takign the (-) term off do?? i dont get it?? i asked my mechanic friend and he said that there is no need to. but whatever
Old Feb 3, 2002 | 10:36 PM
hYpE-R-29's Avatar
there are 2 (7.5 fuses) they both say 7.5a, which one??..is it the one that says 15(fuse)..i think its in the top row...correct me if im wrong
Old Feb 4, 2002 | 04:41 AM
Flux's Avatar
Default Re: Resetting ECU? (fuzznuts)
From what I have heard there is no need to reset the ECU... can anybody confirm this?
Old Feb 4, 2002 | 04:46 AM
DutchITR1689's Avatar
Default Re: Resetting ECU? (Flux)
Most Honda dealer reset the ECU every time the car comes in for maintenance......
Old Feb 4, 2002 | 05:24 AM
i 4's Avatar
i 4
Default Re: Resetting ECU? (EuroITR1689)
This is how i did it :
-Disconnect the battery for 30 minutes
-connect the battery
-without touching the gas pedal start the car and let it iddle for 3 minutes. Then Turn it off.
-you are done, now turn it back on and enjoy...
Old Feb 4, 2002 | 05:25 AM
PM-Performance's Avatar
i think its a waste of time . but go for it.
Old Feb 4, 2002 | 05:28 AM
Dr Pooface's Avatar
Default Re: Resetting ECU? (i 4)
?????????????????????WTF?????????????????????????? ??
Just pull the fuse for 10 secs. I must say, I have never seen proof that resetting the ECU does anything. Back to back dyno runs would be nice, but I think I know what the result would be.
Old Feb 4, 2002 | 05:30 AM
Default Re: Resetting ECU? (Dr Pooface)
It's just like extra grounding wires. If it was needed, you will notice it. If not then you won't......
tbuck23
Apr 1, 2007 05:50 PM
Fatty_1775
Aug 5, 2003 05:37 AM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
cp_harrington
Jan 20, 2003 08:35 PM
illusion
Feb 18, 2002 03:02 PM
