How Muffler piping is measured
"...due to its superior design and function of the pre-formed band that allows the use of O.D. components (exhaust pipe) to I.D. components (muffler)."
I'm thinking about using a band clamp and ran across the above statement. Is this true for mufflers? I know the b-pipe piping is measured in OD, but this is the first time hearing that the muffler pipe would be measured in ID.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">"...due to its superior design and function of the pre-formed band that allows the use of O.D. components (exhaust pipe) to I.D. components (muffler)."</TD></TR></TABLE>That sure sounds like it was written by a salesman not an engineer...
Hondas traditionally used flanged connections between exhaust sections, so it doesn't matter about OD vs. ID.
Lotsa other cars have lap joints where there's an expanded & slit section that's just big enough ID to slide over the OD of the prior section. That's for all pieces, not different for pipes vs. mufflers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">That sure sounds like it was written by a salesman not an engineer...
I have custom piping, and considering using a band clamp so I can swap out different universal exhausts until I find what I want, or rather, what I can deal with. The quoted statement was something that was describing why these band clamps were good.
I just got my muffler, and you are correct. The inner diameter at the ends of the piping on the muffler are 2.5" I wasn't sure if 2.5" inlet/outlet on my muffler meant inner or outer diameter, and now I know it's both. The ends where it meets the other exhaust piping has been expanded slightly, creating a 2.5" ID.
Maybe the advantage they're trying to sell is being able to remove & reinstall that stuff. Normally with those lap joints, a normal clamp deforms the overlapped section, making it very difficult to take apart. But you need to swap parts a few times until you figure out what you need. Maybe don't clamp them very tightly, so they'll come apart OK. They'll probably leak until you settle on a system & tighten it properly.
Or check out those clamps in more detail. I don't really know about them except I can guess. Maybe you have to cut off the expanded section, prepare each end whatever way is required for those clamps? Then you can unclamp them, swap pieces & reassemble without damage. It sort of reminds me of GrayLoc flanges but those are for high-pressure piping.
The part that sold me about the band clamp I bought was the fact that it's "pre-formed" Half of the clamp is 2.5" ID while the other is 2.5" OD, accomodating the diameters of both the loop over axle piping and the "lap-joint" on the muffler...
It should be going on my car as soon as hytech sends me the stuff I ordered.
btw, what is the best way to cut exhaust piping anyway? I know I can use a cheap hand saw, but what is the best way to make sure it's cut perfectly flat/straight? I'll end up sanding the cut area... but I can get **** at times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">btw, what is the best way to cut exhaust piping anyway?</TD></TR></TABLE>I think there's a cutting tool with sharp wheels, sorta like the small tubing cutter that you find at hardware stores for small copper tubing. But it's got 3 or 4 wheels instead of 1, it's bigger & stronger, & I don't own one so I don't know how good it works.
93LSivic
Welding / Fabrication
38
Sep 19, 2006 09:25 AM
SHystrdyGSRtdy
Nov 29, 2004 06:03 PM
DA KING
Nov 20, 2004 05:21 PM
