pistons question
can i take civic si pistons to install on my dx connecting rods because i would like to buy srp 11:1 pistons and this model is for si. The dx piston that srp make have 10,5:1.
[Modified by maximedx, 3:25 AM 2/4/2002]
It is probably the same piston since putting a 11.5:1 piston meant for the stroke of a 1.6L engine on the shortened stroke of a 1.5L would drop the static c/r by about one point.
pins maybe the same, but the pin height on the pistons are different.
Put a 1.5L piston on a 1.6L rod and into a 1.6L block and it will stick out of the block at TDC.
Try it with the head installed = BAM!
95c1v1cs1
Jul 28, 2004 09:44 AM
