SRR endlinks don't fit into my SPC lower control arms!!!! :( can i use other ones?
I bought the SRR sway bar kit and have SPC lower control arms...
the endlink fits through the hole on the arm, but there isn't enough thread to have the nut catch on and tighten the endlink on the arm....
looks like the thread end isn't removeable....
can I use another brand endlink?
I`ll buy those SPC lower control arms from you, If you`re going to sell them.
Let me know...
Let me know...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magic Wheels »</TD></TR><TR><TD CLASS="quote">I`ll buy those SPC lower control arms from you, If you`re going to sell them.
Let me know...</TD></TR></TABLE>
hahaha i don't want to sell them, cuz they are pretty hot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">
hahaha i don't want to sell them, cuz they are pretty hot</TD></TR></TABLE>
But non-functional.
So do you want "hot LCA's", or do you want a sway bar?
But non-functional.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">But non-functional.
So do you want "hot LCA's", or do you want a sway bar?</TD></TR></TABLE>
well the reason i got them was because they are a tad shorter than stock, so it helps with extreme camber issues
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">You couldnt have bought a camber kit? </TD></TR></TABLE>
i did use a camber kit
anyways why are you asking about what i've done and help me with my question...
well the reason i got them was because they are a tad shorter than stock, so it helps with extreme camber issues </TD></TR></TABLE>
I believe they are longer than stock ones, from what i heard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magic Wheels »</TD></TR><TR><TD CLASS="quote">I believe they are longer than stock ones, from what i heard.</TD></TR></TABLE>
you heard wrong,
they are about half an inch shorter...
i looked at them side by side
another reason i forgot to mention why i also got these...
with the normal camber fix, for some reason my 40+ offset rotas will rub my rear
you heard wrong,
you heard wrong,
i looked at them side by side</TD></TR></TABLE>
You right...
they are shorter. My bad.
https://honda-tech.com/zerothread?id=852909&page=1
you heard wrong,
You right...
they are shorter. My bad.https://honda-tech.com/zerothread?id=852909&page=1
markwitdada9
Jan 31, 2006 05:15 PM
