FS: TIAL 35mm EXTERNAL WASTEGATE, TURBONETICS T3/T4 TURBO
FS:
Arias Pistons - rings included 81.5 millimeter, heat coated low compression 9.1:1 (used on a gsr for about 2k miles).........$300
Type R Oil Pump (used on a gsr for 2k miles)...................................pending
2 B16 heads
1 of them is bone stock (no dizzy, cams/gears, intake mani)......$400
1 minty fresh!! bronze valve guides,
crower valvesprings,
skunk2 titanium retainers,
supertech flat top valves
(no dizzy, cams/gears, intake mani).......$800
GSR distributor w/no cap obd2 (no coil - wired for external coil/ignition)..................$175 shipped
Modified by wickedplastikman at 7:52 AM 7/1/2005
2 B16 heads
i should have pics of the turbo and wastegate by monday. as far as the turbo goes, its whatever trim specs of the drag gen 3 kit. i couldnt find the specs online.
pretty sure they are 57 trim, but look on it and see if its a .63 a/r or a .48 a/r on the exhuast side
very interested
very interested
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedplastikman »</TD></TR><TR><TD CLASS="quote">FS:
Tial 35mm external wastegate....................................$210 shipped
Tubonetics T3/T4 turbo from a DRAG GEN III kit (quick spooling efficient up to 18psi on my car).............................................. ........$425 shipped
Arias Pistons - 82 millimeter (used on a gsr for about 2k miles).........$400
Type R Oil Pump (used on a gsr for 2k miles)...................................$100
B16 head (from a 1st gen) - without cams/gears, dizzy, intake manifold......$450
Modified by wickedplastikman at 8:18 AM 5/19/2005</TD></TR></TABLE>
Get real b16a head with no internals or dizzy for $450?
well, that seems to be the going rate around here. if you can find one cheaper, better luck to you. stay the hell off my thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Launchpad »</TD></TR><TR><TD CLASS="quote">
AHHAHA no ****
</TD></TR></TABLE>AHHAHA no ****
josh green
May 23, 2010 04:55 PM
NotUrAvgSi
Dec 22, 2005 01:45 PM
StrokedPSI
Mar 25, 2005 03:55 PM
