NO BRAKES!!
Old May 7, 2005 | 02:23 PM
mikensu's Avatar
Default NO BRAKES!!
I changed the back wheel cylinders and brakes. Then tried to bleed the brakes and I have no brakes. I am sure I did it right because I have bled the slave cylinder and front brakes before. What should I do. Nothing is leaking
Old May 7, 2005 | 02:28 PM
EK k kay's Avatar
Default Re: NO BRAKES!! (mikensu)
You sure you got all the air out of the lines?
Old May 7, 2005 | 02:30 PM
jlacoy82's Avatar
71.192.16.183
Default Re: NO BRAKES!! (chowmien)
If you thought you bled your brakes all the way...........you're wrong.
Go bleed them, then after that bleed them some more.
Then when you are done doing all that......bleed them again.
What I'm trying to say is.....bleed your brakes more.
Oh right, and when I read the thread title, first thing that came to mind was, "I bet he just did a rear brake swap." !!!
Old May 8, 2005 | 06:18 PM
mikensu's Avatar
Default Re: NO BRAKES!! (jlacoy82)
u mean u had the same problem. I have to bleed them more than the front.
Old May 9, 2005 | 12:28 PM
EgRedSi's Avatar
You should have pumped them (while you were bleeding them). You should've had someone watch all the fluid run out. I don't think you did that, try it again.
Old May 9, 2005 | 12:33 PM
BauleyCivic's Avatar
Risky Business
Default Re: NO BRAKES!! (EgRedSi)
I had a problem when installing my pads, I had re-bled everything and my brakes still didn't work. I took off and re-installed the pads, and everything is fine. Try that.
Old May 9, 2005 | 12:44 PM
EgRedSi's Avatar
Default Re: NO BRAKES!! (BauleyCivic)
10,000 posts, wow, that's a lot.
Old May 9, 2005 | 12:53 PM
simplegreenmachine's Avatar
me and my friend did the rear disc break conversion on his car, we bled the brakes alot and it works great
Old May 9, 2005 | 01:08 PM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRedSi &raquo;</TD></TR><TR><TD CLASS="quote">10,000 posts, wow, that's a lot.
BauleyCivic
Mixed Motorsports
(101%)
Online
Moderator on the following forums:
EG+ Civic / Del Sol
Access Level Moderator
Old May 9, 2005 | 01:11 PM
EgRedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
BauleyCivic
Mixed Motorsports
(101%)
Online
EG+ Civic / Del Sol
Hey, how did you 101%? I thought it was impossible to have more than 100% or is it just a Moderator thing? Speaking of that, how do you become a Moderator (I have been wondering that for a while).
Old May 9, 2005 | 01:13 PM
Risky Business
Hey, how did you 101%? I thought it was impossible to have more than 100% or is it just a Moderator thing?</TD></TR></TABLE>
Before I was a moderator I was docked 2% for a rule infraction, and when I earned it back they gave me 101% instead of 100%, don't know why.
Speaking of that, how do you become a Moderator (I have been wondering that for a while). </TD></TR></TABLE>
Thousands of intelligent, thought-provoking posts
Old May 9, 2005 | 01:20 PM
Proglow3's Avatar
I assume that you don't have ABS...Good. Those are a pain in the butt. Now, as far as I know your prop valve separates your brakes FR/RL, FL/RR. Try bleeding your front as well. I'm not positive on Honda's, but some older cars have it like that.
Old May 9, 2005 | 01:22 PM
EgRedSi's Avatar
So in order to be a Moderator you just have to stay around long enough and not get kicked off Honda-Tech?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Thousands of intelligent, thought-provoking posts </TD></TR></TABLE>
Makes sense, I have hundreds of mind numbing posts, I haven't made it to thought provoking.
KevinManzsoto
Jun 16, 2018 02:33 PM
jonzel
Jul 22, 2005 04:28 PM
ComoTeGusta
Nov 28, 2004 12:46 AM
DieMaster
18
Nov 9, 2004 07:41 AM
Leb_CRX
Apr 18, 2002 11:17 PM
