help with engine removal!
Old May 7, 2005 | 01:44 PM
baboonstyle's Avatar
Default help with engine removal!
im swapping out a 96 accord motor and its an auto tranny. there is a hose connected to the bottom of the tranny that goes to the back of the car. Does anyone know how to remove this hose? its a hose on top of another hose.
Old May 8, 2005 | 07:00 AM
deserthonda's Avatar
can you take a pic and post it here? hs therr been any modification done to the car??i am tryinng to picture it but i cannot recall any hoses from bottom of tranny to back of car..When you say back of car how far back?
middle of car? or all the way back??
Old May 9, 2005 | 10:20 AM
Default Re: (deserthonda)
figured it out. its the shift linkage cable. looks alot different on an auto tranny. plus it's a rubber hose. had to remove the exhaust shield, scoot it back, then unscrew 2 10 mm bolts. disconnected the cable from inside the car and slid the whole thing out from the bottom. no mods done. just a straight swap from a motor with a blown headgasket.
Old May 9, 2005 | 11:55 AM
if you had told me what is was i would have told you a much easier and quicker way to disconnect cable from tranny
Old May 10, 2005 | 09:33 AM
bah...why don't you tell me for future references. it looks glued on there.
Old May 10, 2005 | 10:21 AM
if you follow the cable into tranny you got to remove that cover,i think there are 3 12mm bolts ,, pry over locking tab on the 10mm bolt that holds sfiter cable to tranny, remove bolt, get cable out of the way just leave it hang by the way you got to remove that cover and lower shield to remove torque converor bolts
myflyintegra
Feb 19, 2009 08:25 AM
98DC2teg
Feb 22, 2004 09:51 AM
JDM Style EK
Oct 2, 2003 11:40 AM
gvillehnut
Jan 6, 2003 01:31 PM
