LS VTEC TURBO
its costing me about 1500 to make it complete, thats using eagle rods, je pistons, je rings, b16a head that is P and P, aebs headstuds, and all the other stupid **** that makes it work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN »</TD></TR><TR><TD CLASS="quote">its costing me about 1500 to make it complete, thats using eagle rods, je pistons, je rings, b16a head that is P and P, aebs headstuds, and all the other stupid **** that makes it work. </TD></TR></TABLE>
I think its more than that especially if u want a shop to do it for u.
Here was my ls vtec break down:
GSR head - 450
Dizzy- 100
Valve Cover - 80
New NGK spark plugs and wire (ls wont fit) - 100
block guard - 100
AEBS head stud - 120
HP headgasket - 110
catchcan and return line - 150
pistons and rods - 600
Blox intake manifold - 200
Hondata im gasket - 65
MSD coil/ cap - 100
Parts: $2175 (not including MISC stuff like gauges, fuel managment, etc.)
Labor: 500 and up
Advice: I recommand getting the head milled and looked at before installing it. I learned the heard way and when I had the shop put the vtec head on, it leaked
Therefore, I got charged double for the labor. Do it right the first time or it will cost u in the long run
Modified by Mr.DC2TurBo at 4:36 PM 5/7/2005
GSR head - 450
Dizzy- 100
Valve Cover - 80
block guard - 100
HP headgasket - 110
MSD coil/ cap - 100
Labor: 500 and up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo »</TD></TR><TR><TD CLASS="quote">I think its more than that especially if u want a shop to do it for u.
GSR head - 450
Dizzy- 100
Valve Cover - 80
block guard - 100
HP headgasket - 110
MSD coil/ cap - 100
Labor: 500 and up
Modified by Mr.DC2TurBo at 4:36 PM 5/7/2005</TD></TR></TABLE>
well heres where im at, and dont forget we are talking about an engine, not the turbo stuff. im replacing a b16a so i have the tranny and everything else already, just building block and head and sticking it in there. All labor done by me except machine work
block: 100$
B16A head w/P&P - 400
block guard - 70
AEBS head studs - 110
OEM headgasket - 60
catchcan and return line - 80
Machine work: 145
Water Pump: 60
Rings: 85
SS adaption lines: 50$
misc **** left to get: 50$
1810$$
amazed at how much i actually have in it: priceless
DAMN LOL. I never counted, just kept going along.
turbo stuff would be:
Blox Manifold: 300$
SC61: 565$
Downpipe: 150$
custom 3": 100$
HKS Muffler: 210$
HKS BOV: 150$
Piping: 150$
Clamps: 50$
TiAL Wastegate: 150$
Boost controller: 200$
3 Bar map sensor: 50$
Uberdata: 80$
Intercooler: 160(good deal)
Edel Mani: 200$
Injectors: 200$ ish
fuel Pump: 40$
2755$ LOL
GSR head - 450
Dizzy- 100
Valve Cover - 80
block guard - 100
HP headgasket - 110
MSD coil/ cap - 100
Labor: 500 and up
block: 100$
block guard - 70
OEM headgasket - 60
Machine work: 145
Water Pump: 60
Rings: 85
1810$$
Blox Manifold: 300$
SC61: 565$
Downpipe: 150$
custom 3": 100$
HKS Muffler: 210$
HKS BOV: 150$
Piping: 150$
Clamps: 50$
Uberdata: 80$
Edel Mani: 200$
Injectors: 200$ ish
fuel Pump: 40$
2755$ LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN »</TD></TR><TR><TD CLASS="quote">well heres where im at, and dont forget we are talking about an engine, not the turbo stuff. im replacing a b16a so i have the tranny and everything else already, just building block and head and sticking it in there. All labor done by me except machine work
block: 100$
block guard - 70
OEM headgasket - 60
Machine work: 145
Water Pump: 60
Rings: 85
1810$$
Blox Manifold: 300$
SC61: 565$
Downpipe: 150$
custom 3": 100$
HKS Muffler: 210$
HKS BOV: 150$
Piping: 150$
Clamps: 50$
Uberdata: 80$
Edel Mani: 200$
Injectors: 200$ ish
fuel Pump: 40$
2755$ LOL</TD></TR></TABLE>
um you def way low on those prices
my setup
Eq Length Mani: 600$
Holset hx35: 215$
vband dp $40 for the clamp...50 to fab it myself because i own a welder...id say about 200 tohave someone make it for you
dumptube recircualting...$40
Dsm BOV: 30$
Piping: 100$
Clamps homedepot: 50$
TiAL Wastegate: 185$
Boost controller avcr: 275$
3 Bar map sensor: 75$
Uberdata:$100
wbo2 $350
laptop $200
all dataloggin **** $30
Intercooler a/w $250
water pump & resiovor $200
Skunk2 Mani: 200$
Injectors: 280$
fuel Pump: 90$
Wiring **** & ecu harness $125
about 3500 right there...
engine....
pistons & rods $500
machine work bore/hone cleaning & file fit rings $200
all new gaskets & some new bolts $200
ge sandwich ls/vtec kit w/ everything $219
new wires dist cap & rotor $75
plugs $10
gsr head pnp w/ dual springs & valves $900
ls block...freebie
oil pump and h2o pump $200
headstuds $100
tranny fluid $30
clutch & flywheel $500
fluids $50
roughly about 3g's in the motor....now that is considering i assembled everything myself
6500 + motor build + turbo install...labor prob would be right around 1500 or so...so you looking at about 8 grand...and im not even running all the bling bling parts like sc61's....besides my turbo is equally capable for about a 1/3 the price
block: 100$
block guard - 70
OEM headgasket - 60
Machine work: 145
Water Pump: 60
Rings: 85
1810$$
Blox Manifold: 300$
SC61: 565$
Downpipe: 150$
custom 3": 100$
HKS Muffler: 210$
HKS BOV: 150$
Piping: 150$
Clamps: 50$
Uberdata: 80$
Edel Mani: 200$
Injectors: 200$ ish
fuel Pump: 40$
my setupturbo stuff would be:
Holset hx35: 215$
Dsm BOV: 30$
Piping: 100$
Uberdata:$100
wbo2 $350
laptop $200
Skunk2 Mani: 200$
Injectors: 280$
fuel Pump: 90$
engine....
pistons & rods $500
plugs $10
ls block...freebie
headstuds $100
tranny fluid $30
fluids $50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">im about 6g's in the hole....thats w/ forged internals no sleeving...and a whole put together turbo setup...</TD></TR></TABLE>
same here. When i started i planed on it costing ~3K
i do everything myself, wiring and all. tuning and machine work is the only thing not done by me. Im just telling you what i payed for this stuff. i have it all, im a good shopper, and ive got lots of friends with STUFF laying around everywhere. my prices are not low, just good shopping. some stuff you added are valid like fluids though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN »</TD></TR><TR><TD CLASS="quote">i do everything myself, wiring and all. tuning and machine work is the only thing not done by me. Im just telling you what i payed for this stuff. i have it all, im a good shopper, and ive got lots of friends with STUFF laying around everywhere. my prices are not low, just good shopping. some stuff you added are valid like fluids though. </TD></TR></TABLE>
ditto here...shopping around save me some coin...def couldn't have made this all at one point in time...its been 3 years of collecting part by part and changing plans (drag mani & t3 super 60 > eq length & holset hx35)
