Is the prelude f22 block the same as the accords F22B2?
Old May 7, 2005 | 12:08 PM
FTPPRELUDE's Avatar
Default Is the prelude f22 block the same as the accords F22B2?
cause i can get a complete motor for like 150 bucks and just want to make sure it is the same type of block and that the stroke and rod lenght are the same as the H23. Also will the H23 head fit it?
Old May 7, 2005 | 12:18 PM
PHREAK's Avatar
Default Re: Is the prelude f22 block the same as the accords F22B2? (FTPPRELUDE)
i'm pretty sure the H series heads don't bolt to F series blocks, unless you do some serious frankenstein work, blocking oil passages, routing new ones. least from what i've seen. and as long as the prelude isn't type-SH i'm almost certain it would be a match. The difference in the SH is the tranny bolts, if not elsewhere too, hence so many products for "non-SH" ludes. can always double check with honda.
Old May 7, 2005 | 09:33 PM
Nick H's Avatar
New User
Default Re: Is the prelude f22 block the same as the accords F22B2? (PHREAK)
yes, they are both the f22b2 motors...as for the h series head, there have been a couple successful head swaps on this site...you will need to search for them, however...most of the details lie within those particular threads, but to answer your question, yes, it will work...but why not use the h22 head?
Old May 7, 2005 | 11:13 PM
PhildoexAccord's Avatar
YUP
Old May 8, 2005 | 03:52 AM
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHREAK &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure the H series heads don't bolt to F series blocks, unless you do some serious frankenstein work, blocking oil passages, routing new ones. least from what i've seen. and as long as the prelude isn't type-SH i'm almost certain it would be a match. The difference in the SH is the tranny bolts, if not elsewhere too, hence so many products for "non-SH" ludes. can always double check with honda.</TD></TR></TABLE>
some ludes had f22s in them too.
Old May 10, 2005 | 07:27 PM
FTPPRELUDE's Avatar
Default Re: Is the prelude f22 block the same as the accords F22B2? (Nick H)
im one of them anti vtec boys so it will be DOHC non VEEETACH for me. and all of this is going in a first gen CRX
Old May 11, 2005 | 08:59 AM
Lostcb7's Avatar
the f22/h22 hybrid has succesfully been done, with relative ease too. Check out cb7tuner.com for more f22/f and h series hyrbids. I think there is even a write up there on how to do it.
Old May 15, 2005 | 07:37 PM
FTPPRELUDE's Avatar
decent thanks for the link
Old May 15, 2005 | 07:41 PM
JDM Like Whoa's Avatar
ITS MIKE!
Old May 15, 2005 | 07:58 PM
madd's Avatar
why not just use the DOHC F22? unless you wanted to go through the trouble of doing the h22/f22 combo. just a thought...
Old May 16, 2005 | 05:41 PM
FTPPRELUDE's Avatar
is the DOHC f22 Vtec?
1997PreludeH23A
Apr 11, 2013 06:25 PM
en00be
Feb 11, 2009 02:52 PM
swapped95
Mar 18, 2007 03:04 PM
Rishiras
Aug 27, 2005 02:12 PM
ensracer
Mar 23, 2004 04:52 AM
