Rear LCA bushings
Old May 7, 2005 | 07:29 AM
Thrillhouse's Avatar
Default Rear LCA bushings
Right now I am doing the LCAs on an 88 crx. It has the ITR box style LCAs in the rear. When taking these out to put ES bushings in, do I have to take out JUST the rubber part or the metal sleeve too?
Old May 7, 2005 | 09:12 AM
Default Re: Rear LCA bushings (Thrillhouse)
anyone?
Old May 7, 2005 | 10:03 AM
See65's Avatar
Just the rubber.
Old May 7, 2005 | 10:12 AM
fasthatchb18c1's Avatar
Default Re: Rear LCA bushings (See65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See65 &raquo;</TD></TR><TR><TD CLASS="quote">Just the rubber.</TD></TR></TABLE>
no you have to take out the metal sleeve as well.
Old May 7, 2005 | 12:19 PM
Default Re: Rear LCA bushings (fasthatchb18c1)
yeah gotta take out the sleeve, I figured it out, I found a good way to do it too without a press I took pictures and will do a write up later
Old May 7, 2005 | 12:46 PM
Tyson's Avatar
the bushings are different than 89+. are you sure the polys are made for 88's?
Old May 7, 2005 | 12:57 PM
Default Re: Rear LCA bushings (Tyson)
yes, I called ES and the only thing different on the bushings is the shock mount, the other buchings fit they just go in differently cuz of the box style LCA and the solid style.
blk_dc
Suspension & Brakes
Aug 3, 2011 08:11 AM
hondaZvic
19
Aug 24, 2006 08:43 PM
RAB
32
Dec 20, 2004 03:16 PM
RAB
Nov 23, 2004 09:35 AM
