Need help with tranny install!
Old May 6, 2005 | 11:45 PM
CrAzyGsR101's Avatar
Default Need help with tranny install!
Well i am about to take out the old worn CVT Tranny out of a 98 HX Automatic Civic and i was wondering if there are any write ups or if anyone has any info on how to do this. Is it pretty much like a 5-speed tranny where u take out the axles and find all the bolts holding the tranny in place. If anyone has anything specific please help Thanks.
Old May 7, 2005 | 03:52 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Need help with tranny install! (CrAzyGsR101)
Don't forget the rear transmission mount, the front engine torque mount, the slave cylinder as well as the starter. I'd advise the use of a good floor jack and at the least an 8x8 wood board to support and bring down the transmission. When it comes to the rear transmission mount, make sure you know which bolts are welded and which are actual bolts. Once you've removed all the bolts from the transmission, recheck to verify and try prying the transmission off. It doesn't always just slide off.
I'd advise draining your coolant into a bucket as well, either that or zip tie the thermostat housing up to prevent it from draining all over the place.
91civicsikid
Jun 12, 2008 09:37 PM
averyvm
Aug 7, 2007 09:57 PM
Alpinestar03
May 11, 2007 04:26 PM
cincispeedemon
Oct 10, 2004 02:50 PM
h2point2
Apr 16, 2004 12:17 PM
