Suspension & Brakes Theory, alignment, spring rates....
Rear LCA kits & sway bar?
Old May 6, 2005 | 08:54 PM
bebeon_ek's Avatar
Default Rear LCA kits & sway bar?
Hello HT members:
I'm looking to buying a set of lower control arms and sway bars, but undecided on what brand or company to go with. What do you guys recommend for an EK?
How do they handle?
I'm currently running AGX w/Ground Control Springs. I'm planning to add SPC camber kit for the front. Still undecided what kind of cambers to add on the rear.
Is it better to stay with one brand or mismatch?
All SRR, ST, SPC, OMNI, D2, Megan Racing, Function 7 etc. If you know of any others post them and give some information please.
Modified by bebeon_ek at 2:21 PM 5/8/2005
Old May 8, 2005 | 01:22 PM
bebeon_ek's Avatar
Default Re: Rear LCA kits & sway bar? (bebeon_ek)
anyone out there
Old May 8, 2005 | 01:38 PM
usdm_dc2's Avatar
control arms are all about the same. but i would go with a mugen rear sway bar they are like 26mm and are bad ***.
Old May 8, 2005 | 06:31 PM
igo4bmx's Avatar
Default Re: Rear LCA kits & sway bar? (usdm_dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">control arms are all about the same. but i would go with a mugen rear sway bar they are like 26mm and are bad ***.</TD></TR></TABLE>
SPC are shorter by half an inch...
and i know for a fast srr sway bar does not work with the spc arms... the spc arms are too thick to accept the endlinks
Old May 8, 2005 | 09:17 PM
dohcdelsol's Avatar
Default Re: Rear LCA kits & sway bar? (igo4bmx)
DO NOT GET MEGAN RACING LCAS!!!!!!!!!!!!!
With that said... personally i'd rock the stockers with es bushings... cant really go rong their unless ur going for the bling factor. I dont know if the eks came with a stock sway bar but if not, the factor7's use the es bushing. Heard good things with srr
Old May 9, 2005 | 09:27 AM
pgpunkguy's Avatar
Default Re: Rear LCA kits & sway bar? (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT GET MEGAN RACING LCAS!!!!!!!!!!!!!
With that said... personally i'd rock the stockers with es bushings... cant really go rong their unless ur going for the bling factor. I dont know if the eks came with a stock sway bar but if not, the factor7's use the es bushing. Heard good things with srr</TD></TR></TABLE>
what is wrong with megan racing LCAs?
is the problem just for the EK or EG too?
i'm looking at aftermarket LCAs to use with swaybar...
Old May 9, 2005 | 05:44 PM
dohcdelsol's Avatar
Default Re: Rear LCA kits & sway bar? (pgpunkguy)
the megan racing lcas suck
reasons:
A friend of mine with an EK, after instulation, went threw the bushings within a month and a half time.
The bushings can not be replaced with oem ones/es/or mugens. (not 100% on the mugens though)
Dealing with the megan company sucked because i ordered parts from them and they never shipped them yet they billed me on items never received. It was about 5 months later until they sent me my items. to their customer service.
With my eg, one of the bushing wasnt pressed in straight. It was on a hardcore angle downwards. When i instuled them, i got the shock bolt in and the knuckle bolt in fine. The subframe took a long time to get it to line up. I had to twist the lca with a wrench to get it to line up. Since then, about 3 weeks later, the bushing was totally torn and lose.
So my experience with the megan racing lcas got me to the conclusion that they suck!
Old May 9, 2005 | 10:03 PM
bebeon_ek's Avatar
SRR
SPC
or
type-R
Old May 10, 2005 | 09:22 PM
bebeon_ek's Avatar
The Type-R look like Stock. Whats some bad azz about them?
Old May 10, 2005 | 09:24 PM
bebeon_ek's Avatar
Does anybody have the Invidia Civic EK Rear Sway Bar w Tie Bar Kit that JHPUSA has for sale?
Old May 11, 2005 | 09:54 AM
pgpunkguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">the megan racing lcas suck
reasons:
So my experience with the megan racing lcas got me to the conclusion that they suck!</TD></TR></TABLE>
so are you rolling with a new LCA?
Old May 11, 2005 | 09:10 PM
slimstajimsta5's Avatar
I have SPC rear lower control arms in silver, i love them. my car only has about a finger gap in the back with the tire/fender, and my camber is almost perfect because of how the SPC RLCA's pulled in the tires :-p
Old May 15, 2005 | 07:23 AM
Fastrax203's Avatar
im using Megan LCAs now and i dont have a single problem with them...did u make sure to use the allen screws on the top of each bushing to secure them?
Old May 15, 2005 | 07:45 AM
dohcdelsol's Avatar
Default Re: (Fastrax203)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fastrax203 &raquo;</TD></TR><TR><TD CLASS="quote">im using Megan LCAs now and i dont have a single problem with them...did u make sure to use the allen screws on the top of each bushing to secure them?</TD></TR></TABLE>
Yup.... just wait a few months especially in the winter.. bushings will be shot.
This was also when these lcas cost about 125. If your using all the stock suspension, you might not have a problem with them, but they get chewed up in a lowered car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">
so are you rolling with a new LCA?</TD></TR></TABLE>
Yeah.. i swapped in some gsr lca's with energy suspension bushings
I can deff tell the different over the megan lcas..... **** is just tighter
Old May 15, 2005 | 03:36 PM
bebeon_ek's Avatar
Default Re: (dohcdelsol)
I'm thinking of going with the Type-R RLCA because I just got a 95 GSR disc break conversion for my car.
I did find some NEW SRR RLCA for $120.
But I need to find out if the Invidia 96-00 Civic EK Rear Sway Bar w Tie Bar Kit
Will fit the Type-R RLCA or SRR RLCA.
Type R RLCA
SRR RLCA
Also Looking at getting the JDM Password 3 Point Front Solid Tower Bar
Honda-Tech Members give me some feed back Please ( Good Or Bad )
Old May 15, 2005 | 04:30 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebeon_ek &raquo;</TD></TR><TR><TD CLASS="quote">The Type-R look like Stock. Whats some bad azz about them?
Because they fit right, the bushings dont suck, and they wont break, and if you buy them new they come with new OEM bushings installed.
I'd go with OEM LCA's.
Old May 16, 2005 | 12:19 AM
vtakk eg's Avatar
Default Re: Rear LCA kits & sway bar? (.RJ)
where can i find some of those srr for my eg
Old May 16, 2005 | 05:40 PM
JOHN WAYNE's Avatar
Default Re: Rear LCA kits & sway bar? (JDMjunkyard)
since when do ITR rear LCA's fit on an EK??
Old May 16, 2005 | 05:48 PM
.RJ's Avatar
.RJ
Default Re: Rear LCA kits & sway bar? (JOHN WAYNE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOHN WAYNE &raquo;</TD></TR><TR><TD CLASS="quote">since when do ITR rear LCA's fit on an EK??</TD></TR></TABLE>
Why wouldnt they? the only difference is the width of the bushing.
Old May 16, 2005 | 06:19 PM
JOHN WAYNE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Why wouldnt they? the only difference is the width of the bushing.</TD></TR></TABLE>
i was under the impression that they were slightly different in length?
which bushing is different? the subframe side?
i wonder why more people with EK's dont use ITR LCA's...they are definitely a solid piece.
Old May 16, 2005 | 07:07 PM
nonsense's Avatar
i wonder why more people with EK's dont use ITR LCA's...they are definitely a solid piece.</TD></TR></TABLE>
cause stock = free and ITR = $$$, plus you have to run different rear shocks with the ITR rear LCA's
Old May 17, 2005 | 02:45 AM
JOHN WAYNE's Avatar
Default Re: Rear LCA kits & sway bar? (nonsense)
well after some searching...apparently the ITR's are a different length as i had thought...
https://honda-tech.com/zerothread?id=766995
https://honda-tech.com/zerothread?id=78215
Old May 20, 2005 | 11:21 PM
bebeon_ek's Avatar
I was told to run 99-00 Si RLCA and sway bar
Any body have any feed back?
Old May 21, 2005 | 10:30 AM
JOHN WAYNE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebeon_ek &raquo;</TD></TR><TR><TD CLASS="quote">I was told to run 99-00 Si RLCA and sway bar
Any body have any feed back? </TD></TR></TABLE>
the rear LCA on the si are the same as any other trim level civic...
the rear bar is like 13 or 15mm which is WAY too small. get yourself a USDM ITR 22mm bar...and put an ex 22mm bar in the front while youre at it.
Old May 24, 2005 | 01:30 PM
DavidR's Avatar
How about a set of the strongest LCAs on the market?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Features
High quality Energy Suspension polyurethane bushings provide extended life.
Aluminum CNC bushing inserts prevents rust related issues found on stock bushings.
Modular design allows individual component replacement and makes bushing rebuilds simple.
Entrapment-type bushings do not require set screws which cause undue stress points.
Full width bushing journals for maximum strength & reliability under the most extreme conditions.
Micro-engraving ensures that the product is a genuine Function7 product.
Each arm is individually serialized & bar coded for quality control and trackability.
Sway bar mounting holes are provided for the easy installation of most factory and aftermarket sway bars.
Optional sway bar linkages are available to mount factory and aftermarket sway bars.
